Question about Gigabyte GA-8LD533 Motherboard
Usb keyboard not support windowsxp
Logitech keyboard notsupporting gigabyte motherboard forwindowsxp
    Guru:
  • 859 Answers
You using a USB connection wtih a USB cable from Logitech? And, did you keyboard come with a USB to PS2 adapter plug.
Because you would have to use this adapter and then install the Logitech software, once that is done you can shut down and use the USB connector from that point onwards unless you would just feel more comfortable with the PS2 connector.
Otherwise you will need to borrow or use a PS2 keyboard boot up into Windows, install the logitech software, shut down and then try attaching your USB keyboard and you should be fine after that.
Regards,
Worldvet
Please don't forget to rate our solutions on FixYa, thanks.
Posted on Jun 25, 2008
GA- F2A85X-UP4, can't bring up initial bios, upon build
Gigabyte motherboards boot to BIOS setup by pressing 'del' at startup. if this doesn't work, it may mean that the boot-time usb support for keyboards isn't activated, which means your usb-keyboard only works when windows is loaded. if you have a usb-keyboard, you can get around this by attaching a PS-2 keyboard or putting a PS-2 adapter between your keyboard and the pc.
Oct 12, 2013 | Computers & Internet
Ports for keyboard and mouse does not work
If you have usb ports then purchase a usb mouse and keyboard.
May 02, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I Have a 945GZM-S2 Motherboard. I want to get into Bios but delete key doesn't work on restart. It would appear that the keyboard is not connected. I have just bought new hard drive and I want to...
The keyboard may be faulty, try a different keyboard, but don't use an USB keyboard because an USB keyboard may not be recognised until Windows is running.
Jun 17, 2011 | Gigabyte GA-945GZM-S2 Motherboard
Hi ive got a gigabyte ga-g41m motherboard and when i turn on my pc it wont power up my usb keyboard in order for me to set up bios it stays on the post screen
test the usb lead make sure its not faulty or try another keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
Nov 28, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Can I enable USB support in BIOS without keyboard?
I would first test your motherboard to see if it could do this. Most motherboards nowadays automatically detect USB keyboards and mice, and allow them to be used in the BIOS.
If this isn't the case, I would update your bios with newer firmware. Boot up the computer, check the Gigabyte website for these updates, and apply them (hopefully the computer will let you continue if it can't find the keyboard) After they are applied, the computer should be able to boot from USB.
Those are my two suggestions, but they are assuming you are lucky. If neither solution works, you may need to buy another motherboard, or see if you can clean the PS/2 ports with a can of compressed air, just in case it's a dust or dirt-based blockage preventing you from using them.
Hope this helps....
Jun 30, 2010 | Gigabyte GA-6OXET (GA-60XET) Motherboard
Usb not working drivers installed
I assume you are talking about mouse/keyboard usb devices. If you are then you should check your bios settings to see if keyboard/mouse usb is Enabled. To get into bios, restart your computer and the DEL key (if you can't get your keyboard working at all you may need to switch to a ps/2 connection keyboard in order to enable it first). Worst case scenario is that you need a new motherboard as the ports may have died.
Jun 09, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
New system, stuck at the Gigabyte Logo screen with no keyboard
It is a CMOS PROM problem. Better to go for a replacement of the mother board.
Apr 17, 2009 | Intel Motherboard
Keyboard does not respond prior to windows launch
Have you configured the Usb Legacy support in the bios? If not you'll need to enable Usb keyboard support in the bios for the keyboard to function correctly or at all in a 16bit environment.
Feb 05, 2007 | Logitech G15
Gigabyte GA-8LD533 Motherboard Logo
56 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
