Question about JVC AV-48WP30 48" Rear Projection Television
Clicking Sound So I replaced the green CRT along with the convergence ICS. The Tv would turn on before and now the blue LED comes on, but there is no picture or sound and a clicking (surging sound) is coming from a component inside. It also will not power off without unplugging it. Any Ideas??? Thanks
  • 1 more comment
  • jrparker4 Jun 25, 2008
    I cleaned up the solder joints and now the clicking is gone, but now when I power up it is like it just kicks back off and the front led is blinking at 0.1 sec intervals. What now??
  • jrparker4 Jun 30, 2008
    I cleaned the solder joints up again and used a magnifying glass. Still same problem.... The sound was coming from the horizontal drive transformer I think. What now??
  • jrparker4 Jul 01, 2008
    Well the souund is gone now. It just powers up, and as soon as the high voltage comes on it turns off and a minute later the led flashes.
It was a clicking sound, but right before it quit it became a cracking sound. It no longer makes any sound just sounds like it is turning off.
Posted on Jul 01, 2008
    Scholar:
  • 167 Answers
HELLO. YES U NEED TO GO OVER WHERE SOLDERED THE NEW CONVERGECE ICS AND CHECK THEM TO MAKE SURE THAT U DO NOT HAVE, ANY OF THE CONCETION'S TOUCHING EACH OTHER.!!! AND THAT THERE IN THE SAME PLACE WHERE THE OLD ONE'S WAS HOOKED UP. TO THE BOARD.!!! AND ALSO CHECK THE REEN CRT GUN U PUT IN AND MAKE SURE THAT NONE OF THE WIRE'S ARE TOUCHING ANYTHING.!!! ON THE BOARD OR ANY WHERE ELSE ON ANY OF THE BOARD'S .!!! AND THAT THE WIRE'S ARE HOOKED UP THE WAY THE OLD ONE'S WAS. HO[PE THIS HELP'S U. "GOOD LUCK"
Posted on Jun 25, 2008
  • 1 more comment
  • MICHAEL WALLACE
    MICHAEL WALLACE Jun 26, 2008
    hello. well you going in the right derection.!! u need to check the ics. concetion again and u a magnafier to look at each concetion to mack sure that they are not touching oneanother.!!! and are making contack. to the isc. . if u know how to use a meter.!!! that would be a big help.to you.!! let me know if this help you.!!! "good luck"
  • MICHAEL WALLACE
    MICHAEL WALLACE Jul 01, 2008
    hello. ok you say that the sound is coming from the horizonal drive transformer.? you think.!!! well. u need to know for sure .!!!. what.??? is making the sound. a good way is to use a old long paper towel tube.!!! to listen with .!!! to try to pin pont where the sound is comming from.!! for sure. !!! try that and let me know . ok !! "good luck"
  • MICHAEL WALLACE
    TELL ME DOS'E IT MAKE A CRACKING SOUND WHEN IT START'S UP.?OR A CLICK SOUND.?
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
TV Want Power up
This tv have different causes for no power.
Can you tell me if any light on the chassis is off?, if so, let me know the location part number.
Common problem is IC output ( short) or convergence STKs ICs.
Thank you
Jul 26, 2009 | Hitachi 43FDX01B TV
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
No raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Jun 12, 2008 | Hitachi 53UWX10B 53" Rear Projection...
No blue convergance
need to replace the convergence ICs. If you need a link to get replacement ICs let me know.
Jun 07, 2008 | Samsung PCJ522R 52" Rear Projection...
Convergence ICs
the green is half controlled by half of each of the convergence Ics meaning green horizontal is controled along with the red and green vertcal is controlled along with the blue Ics. So if you have replaced both Convergencs ICs the problem is most likely a resistor that is in the green circuit. You will need a schematic to locate which resistors are in the green vertical and horizontal convergence circuit
Jun 07, 2008 | Toshiba 55H70 55" Rear Projection...
Colored lines through my tv
Convergence problem; requires 2 STK392-110 ICs and possibly burnt resistors replaced.
Apr 26, 2008 | Hitachi 43FDX01B TV
JVC AV-48WP30 48" Rear Projection Television Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
