Question about HP LaserJet 2420 Printer
Big noise I replace the fuser unit and the printer make a big noise when I printing. Whats wrong? toner cartridge, fuser unit or another thing?
  • meshad Jul 28, 2008
    make noice after replace fuser film
    Problem Solver:
  • 14 Answers
If the printer was not making the noise before you replaced the fuser unit I would try the following:
1. remove and re-seat the new fuser unit and try a test print.
2. if it still makes noise, remove the new fuser unit and replace the old fuser unit and try a test print. (if you waited untill the printer refused to print on the old fuser this might not work).
If you don't get the noise with the old fuser, then it's possible that the new fuser is defective. You could try returning it for replacement at this point. If you still get the noise with the old fuser, then possibly it is not seated correctly or the latches aren't locked or there is some other unrelated issue.
Posted on Jun 25, 2008
It is the fuser, It's sit to strong. loosen the left scruw a little and try again. Put a blade-ring round the screw between the fuser and the frame
Posted on Aug 01, 2008
  • bruce_hamlin Sep 21, 2011
    I had the same problem. Putting a washer on the left side on the lower screw and on the left side on the guide post between the fuser and frame fixed the noise.
HP CP1515n Toner tray stuck on right side
you should check transfer belt or fuser unit.
Aug 24, 2016 | HP LaserJet CP1515n Printer
Whats a printer drum
No. The toner cartridge holds the toner while the drum grabs toner that looks like the image you're trying to print and sends it to the fuser for fusing.
Nov 29, 2011 | Brother HL-2170W Laser Printer
HP LaserJet 1020 Printer Black leaving a black line on the left side of paper. What is causing this
Lines down the page can be caused by a few different things. The most common are the toner cartridge having a defect, or the fuser being worn out. The quickest way to figure out which one is to do a "half print" test. You need to start a print job, then open the toner cover when about half the page has been printed. Check and see if the line is on the page. If it is, then the toner cartridge is to blame. If it isn't, then the fuser will be the problem. (not worth replacing the fuser on this unit)
Be careful of the toner on the page with this test...it will not be attached to the paper and will rub off easily.
Hope this was helpful
Jul 26, 2011 | HP LaserJet 1020 Printer
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
Hp 1505n laser jet, Makes clicking noises when printing. Slight smear on left side of page.
There are two things that can cause print quality problems and a noises. One being the toner cartridge and the other being the fuser assembly. If you have already replaced the toner cartridge and it did not take care of the problem then the fuser may need to be replaced. You can take it to a local printer repair shop to get it fixed.
Sep 16, 2010 | HP LaserJet P1505n Printer
The printer makes an usual noise while printing, the print out is faded on one side and has black soot like marks on the right side. what is wrong?
Only 2 possibilities. The most common cause and the easiest to check is the toner cartridge. If you have a spare just swap out the cartridge and try another print to see if it clears. If you do not have a spare take out the toner cartridge and turn it over. Open the gate that covers the drum and see if you see the same smudges on one side of the drum. If so then it is the cartridge as this drum should be clean.
If the drum is clean or a cartridge swap does not fix the problem then the problem is the fusing unit or more specifically the fuser film is bad. You will then need to do a fuser change or get a local person out to change the "fuser film" About $150 total if they do the film, about $300 if they do a fuser unit complete.
May 18, 2010 | HP LaserJet 2420 Printer
Dark lines appear on each page I print on the printer. I have cleaned every roller, dumped the old toner and added new toner.
Are the lines vertical or horizontal?
vertical lines can be caused by several things.
Since you said that cleaned the rollers, then here are other options
1: Most common is a bad toner cartridge.
2: try cleaning the fuser entrance guide.
3: could be a defective formatter - formatter replacement the fix.
4: worn fuser. fuser replacement is the fix.
horizontal lines are probably repetitive down the page, and are usually caused by a defective toner cartridge or fuser assembly. occasionaly a transfer roller will cause it as well.
Toner loves to get baked onto the fuser and cause all kinds of print problems. Not much you can do but to replace the fuser when this happens.
Oct 17, 2009 | OKI OL 400e Led Printer
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Hp 4600 noise problem
when power on the main board do initial devices:
1) the cartridge include toner unit and photo drum unit
2) fuser unit and all paper road include motors and sensors through the paper road.
the noise at power on you may check:
1) the toner unit that maybe over life cycle to mak much more obstruction, you may take out the cartridge and turn the gears if felling very hard so need to change the cartridge.
2) the toner unit gears damage a little that could make noise, you may check all gears on the cartridge. attention other side drive gears.
3) check the fuser unit gears do same thing above.
hope you fix it and feedback the result thanks
May 06, 2009 | HP LaserJet 4600dn Color Printer
Roller marks on paper
Hi, Sounds like your problem is not the rollers. If its marked on the pages, its not the pickup rollers nor the Exit rollers that leave marks.
Either 1 you have a bad Toner Cartridge. or 2 Fuser sleeve is bad and needs to be replaced.
(1) If the toner cartridge is refurbished that is your first indication that you should replace with a HP Manufactured Toner. Refurbished toners always go bad. In fact many of them do not even last the amount they are said to last.
(2) If its not the toner cartridge, then the only other thing that is fusing roller marks is the fuser. In order to do this. You will have to remove the back panel. Unscrew the fuser.*note fuser can be extremely hot after use. be careful.* From this point you should be able to look at the Fuser sleeve and see a worn out sleeve on the side which your roller marks are at. You will either need to replace it if it looks bad. Or you can clean it when its got with a piece of paper or an alcohol pad to remove excess toner clocked on the fuser.
That toner is whats showing up as roller marks on your prints.
I hope this helps. PLEASE RATE Porfavor :)
Victor C.
If you need more detailed help please comment back ill be willing to help. I like helping others.
Sep 23, 2008 | HP LaserJet 2100 Printer
HP LaserJet 2420 Printer Logo
870 people viewed this question
Seeker5211
Seeker5211
