Question about HP LaserJet 4 plus Printer
50 Service I have read some of the solutions. I dont get Fuser resetting can u explain pls.
  • Anonymous Jul 22, 2008
    50 service
I want to be a driver in prienter
Posted on Jun 27, 2008
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Will not print.
LaserJet 4V ***If it is intermittent or can be cleared by shutting it off to let it cool. The fuser is running too hot, order rebuilt.***
Notes to remember!!
  • The low voltage power supply is what the takes the 110v ac from the outlet and is for this reason often mistaken as the high voltage power supply. The high voltage power supply HVPS main purpose is to charge the toner cartridge with a much higher dc voltage.
  • Always Remove Power from the printer before working on it!
  • Lamps can break in shipping or if the fuser is dropped.
  • The fusers use floating connectors don't force them in.
Jun 25, 2008 | HP LaserJet 4mv Printer
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
I have hp colour laserjet cm6040f mfp, that displays error 50.A fuser error. pls your help is so much important
You will need to order a fuser and replace it or call a service tech who can. The problem is that the electronics on the fuser have actually burned out, so that is why the whole fuser needs to be replaced.
Aug 29, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
Error e000004-0010 how to solve
I'm not a Canon Copier Tec but I know E04's on Canons generally means heat/fuser error - ie fuser, usally fuser lamp, thermister or thermal fuse. Have fuser replaced.
Have it looked at, due to it requiring electrical knowledge, ie test heater lamp(open), thermal fuse(open), thermister(check for toner built up on face) with the user removed from printer (fuser=hot bit that paper goes threw, just before where paper exits to go to sorter) or just replace assem.
There maybe a reset required, on some canon models after problem has been fixed.
So here is a link with explaination of the reset on a canon model simular to yours http://www.copytechnet.com/forums/canon/2673-error-code-e004-canon-np-6330-a.html
pls vote me to keep us alive
Nov 17, 2010 | Office Equipment & Supplies
FUSER COUNT RESET
The above solution doesn't help, the poster requested how to reset the fuser count replacing the fuser doesn't automatically reset the counter.
Aug 12, 2010 | Brother HL 5250DN Laser Printer
Hp 4m shows service error 50
The service 50 error indicates a bad fuser assembly. You can get one on Ebay for less than $50. To replace the fuser just open the door on the back of the printer, inside you will see the fuser, unscrew the 2 screws and pull the old one out. Insert the new fuser and screw it down, power on the printer and you should be good to go.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 13, 2009 | HP : HP4 Laserjet Printer
Cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
Resetting lbp fuser
you need to do a lbp fuser reset and lbp error log clear
fuser reset
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, then press 7- start- down arrow - start- then yes
log clear
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, the press 6 - use the down arrow to get to lbp log clear.
if this does no work you need the fuser replaced
good luck
Oct 12, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
HP LaserJet 4 plus Printer Logo
106 people viewed this question
Seeker5211
Seeker5211
