Question about Lenovo 3000 C200 Notebook
Can not find script file
When i start windows it displays can't find script file"c:win32oot.vbs"
    Champion:
  • 258 Answers
My friend that is VIRUS I think.
Win32.VBS.Indra.01 is Trojan Creator - spyware.
You should remove it from your system as soon as possible.
This Trojan Creator is also known as: •Virus Constructor - named by Panda.
Posted on Jul 29, 2008
I have just bought a new Aspre One Notebook D270,
Jul 07, 2017 | Acer Computers & Internet
Tip
How to Encode your VBS and JS files for secure website uploading
If you are still at Service Pack 2 then you can use Microsoft's own Script Encoder download it from HERE it's a command line version so after you have installed it you need to run the command prompt also make sure the Windows Scripting Host is started.
REMEMBER MAKE YOUR SCRIPTS "FOR YOUR EYES ONLY"
For both Visual Basic Scripts and JavaScript you will need to format the text in your script to look like this;
Replace your code goes here with your actual code when the encoder has been run then you will see that the <SCRIPT LANGUAGE= ********> will have changed to <SCRIPT LANGUAGE= ********.encode> and your code will be random characters.
The Syntax for the encoder from the command prompt is;
Recognized file extensions are .js and .vbs, which are changed to .jse and .vbe, respectively, after encoding, also these type of files can be decoded if you know what you are doing and therefore not totally hacker proof.
IF YOU HAVE SERVICE PACK 3 installed then this won't work at all so the best method is to use this VBS2EXE this is also a command prompt program you must make sure that the script that you want to convert is in the same root folder.
When finished there will be a new file about 10 times larger then the script with the EXE file extension if you try to edit it all the code appears random this is the best method for encoding your scripts
If you want to do it ALL online and feel secure then you can do both VBS (VIsual Basic Script) and (JS) JavaScript using this website below but it is limited to 10kb per file
http://www.f2ko.de/ov2e/ov2e.html
If you create alot of batch files then I suggest that you also check out their BAT2EXE v1.5 this will convert CMD or BAT files into EXE files for web distribution you can also password protect and add a decompiler if required
on May 30, 2010 | Microsoft Windows XP Professional SP2
On startup cannot find script file 'cleanvirus.vbs'
May be you affected with a virus or missing some files...try to restore go to start /Accessories/System tools/System restore...try it
Feb 04, 2010 | Microsoft Windows XP Home Edition
I am not able to edit my basic info.
Hi, what basic info exactly are you talking about?
Computer owner / organisation?
If you would like to use a script to change your owner / organisation, please follow the steps below.
NOTE: Executing a .VBS script is usually not a good idea, unless you know what you are doing. Please carefully follow the instructions below.
Below is a custom script made to change your owner/organisation.
Press Start->Run
type notepad.exe, press Enter
copy and paste the following:
'ChgOwnOrg.vbs - Change Win9x Registered Owner/Organization.
'© Bill James - billjames.geo@yahoo.com - rev 29 Oct 1999.
'Modified for Windows XP
Option Explicit
Set ws = WScript.CreateObject("WScript.Shell")
Dim ws, t, p1, p2, n, g, cn, cg
Dim itemtype
p1 = "HKLM\Software\Microsoft\Windows NT\CurrentVersion\"
n = ws.RegRead(p1 & "RegisteredOwner")
g = ws.RegRead(p1 & "RegisteredOrganization")
t = "Change Owner and Organization Utility"
cn = InputBox("Type new Owner and click OK", t, n)
If cn <> "" Then
ws.RegWrite p1 & "RegisteredOwner", cn
End If
cg = InputBox("Type new Organization and click OK.", t, g)
If cg <> "" Then
ws.RegWrite p1 & "RegisteredOrganization", cg
End If
--- Stop copying here. DO NOT COPY THIS LINE ---
If you feel at all unsure, do not run this script. All it does it change your Owner and Organisation of the computer.
Save that file (in notepad) as "Change Info.vbs"
Note that you will have to change the "Save as type" to "All Files"
After you are done saving it, close notepad and double click "Change Info.vbs" and it will ask you to enter first your name, and then your organisation.
If this wasn't what you were asking about, or if you don't want to run a .vbs script (I can understand), please let us know.
Dec 14, 2009 | Computers & Internet
My computer is not creating Restore Points... yes it's turned on... yes I know how to do a manual... but it disappears when the next Restore Point is created... can you help?
Creating a System Restore point using a shortcut For a more elegant way to create a System Restore point using Script in Windows Vista, check out our article Create System Restore Points Quickly using Script in Windows Vista and Windows XP.
Alternately, you may use the method below:
Copy the contents below to a Notepad document, and save it to a file name with .vbs extension (Example: createrp.vbs) and close Notepad.
set SRP = getobject("winmgmts:\\.\root\default:Systemrestore")
CSRP = SRP.createrestorepoint ("Created a Restore Point now", 0, 100)
If CSRP <> 0 then
Msgbox "Error " & CSRP & ": Unable to create System Restore point"
End if
Right-click on the Desktop and select New - Shortcut
Create a shortcut with the following target:
wscript.exe c:\scripts\createrp.vbs
Note: The above assumes that the createrp.vbs script is present in the c:\scripts folder. If that's not the case, change the Path accordingly.
Name the shortcut file name as Create Restore Point
Running the script To create a System Restore point, run the script with elevated mode. To do so, right-click on the newly created shortcut (Create Restore Point.lnk) and choose Run as administrator. When you are prompted for an administrator password or confirmation, type the password or provide confirmation. A System Restore point will automatically be created.
Nov 23, 2009 | Microsoft Windows Vista Home Premium with...
Can not find script file cleanvirus vbs
Can not Find. Script File
C:\WINDOWS\System32\CleanViirus.vbs
Oct 22, 2009 | Microsoft Windows XP Professional With...
Loadig script C WINDOWS System32 scvhost vbs
your svchost file is been couruted or damaged, get ur system formated by well qualified engineer and first antivirus installed.
Jun 20, 2009 | Computers & Internet
Script file "c:\Documents and Setting\Quality\boot.vbs".
I guess this is a Startup item on your computer and you can easily remove this from your computer by going in to the registry. But, before that to make sure you can try disabling it from the system configuration utility..
In order to do that, click Start -> Run -> Msconfig -> Ok
Click Startup tab and look for the entry boot.vbs..
Simply clear the check box and restart the computer..
Lemme know the result.. if it works then i can assist you in removing it permanently.
Jun 18, 2008 | Microsoft Windows XP Professional
Problem while starting computer
Hello..
TO remove this error messege follow these steps.
type "regedit" in run dialog box.
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
There is a string value named "userinit".
The value of this key should "c:\windows\system32\userinint.exe"
Delete anything thing after this.
Now logoff and relogin or Reboot.
Jun 09, 2008 | Computers & Internet
Funny UST Scandal
hi my friend got that last week to... ehat you need to do is download kaspersky. after running kaspersky. that will be gone. you can download kaspersky @ majorgeeks.com Here are some examples of autorun viruses which rely on the autorun function of Windows to infect PC’s and flash drives. Funny UST Scandal.avi.exe Autorun.vbs win32.autorun.k copy.exe imgkulot taga lipa are autorun.vbs recycler FS6519.dll.vbs strawberry from baguio W32/Perlovga (copy.exe | host.exe) VBS_RESULOWS.A Bha.dll.vbs w32automa worm (Autorun.vbs) Trojan.Win32.VB.atg | Win32/Dzan | Worm_vb.bnr (tel.xls.exe | mmc.exe) W32/RJump.worm (RavMonE) Worm.Win32.Delf.bf | W32.Fujacks (spoclsv.exe) W32.Fujacks.BH (****.vbs) WORM_AGENT.PGV (soundmix.exe) W32/Hakaglan.worm (RVHost.exe) Trojan.Win32.VB.ayo [AVP] (Macromedia_Setup.exe) Trojan.VBS.DeltreeY.b#1 (Destrukto!!! | destrukto.vbs) if you want to manually delete it... Solution is here: 1. Start Notepad [Start Menu-All Programs-Accessories-Notepad] or right-click any empty space in your desktop then select New-Text Document 2. Copy the following text. (note: Everything in between the square brackets should be in one line) REGEDIT4 [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionIniFileMappingAutorun.inf] @="@SYS:DoesNotExist" 3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part) 4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear. hope this helps
Jan 24, 2008 | Computers & Internet
Lenovo 3000 C200 Notebook Logo
165 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
