Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Beumatic bdw14 - e4 code keeps fashing on machine. cleaned spaying arms and followed advise given in instruction manual but still displaying code after 4 day can you give any more solutions e4 flashing
OK - sorted it finally!
If you, like me, had actually added water thinking that this would rinse the machine through... doh! you had inadvertantly made water fill the cavity at the bottom of the maching. This is situated behind the kick-board. There are 2 black plastic panels - if you remove these, (they just pop out) and sponge out the water that is activating the dip switch (there is a polystirene float) that activates the pump - this resolves the E4 error code.
Make sure you do it while the machine is off! The reason the base of the machine has filled with water may need further investigation, but mine was most definitely user error. Who'd of thought adding water to a dishwasher could have been so fatal! It nearly cost me £88 call out charge too after the helpline weren't able to help me.
Posted on Jul 17, 2008
Baumatic bdw14 e4
already addressed in next post on this topic.
Apr 25, 2014 | Baumatic Dishwashers
E4 message
contact singer customer service about the error code e4, the resistance could be a broken or damaged part.
Mar 22, 2014 | Singer Sewing Machines
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
Whirlpool AWOD6727 washing machine displaying error code "F23". Help please?!?!
Could be a slow drain time issue. Excess wear makes it drain slow.
Mar 17, 2017 | Whirlpool Washing Machines
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Feb 26, 2011 | Office Equipment & Supplies
E4 code on model epc460 pressure cooker
I have a programmable pressure cooker with no instruction manual. The model number is EPC460. It was made in China and just says Perfect Programmable Pressure Cooker. Can you help me find a user manual for this. I can't find anything online or by googling it.
Thank you
Jan 21, 2009 | Cook's Essentials Cooks Essentials Arome...
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Beumatic
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
569 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
