LEEM PRO 105C POWER AMPLIFIER SECTION
I AM LOOKING FOR A CIRCUIT DIAGRAM FOR THE LEEM PRO AMPLIFIER SECTION
THANKS ERIC
  • 44 Answers
SOURCE: Harman Kardon avr 1500 service manual
try here - http://www.harmankardon.com/product_support/support_detail.aspx?prod=AVR500
Posted on Dec 16, 2007
SOURCE: leem power mixer spare part
Have you tried a 2sd6041? sometimes japanese trannys use this prefix.
Posted on Sep 20, 2008
  • 905 Answers
SOURCE: leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Posted on Oct 08, 2008
  • 84 Answers
SOURCE: circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Posted on Jun 14, 2009
mislamy15m
SOURCE: Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Posted on Aug 28, 2011
I need help with the schematic diagram of a JVC RX-5THPBK power amplifier
Have you checked into SAM'S FOTOFAX or other searchers, or do you have schematic and need interp. of it?
Aug 03, 2016 | JVC Audio Players & Recorders
Wharfedale pro BX1360SD powered mixer intermittent fault - preamp section OK, no output from power amp (false overtemp detection? shutting down power amp??) please supply advice, circuit...
Wharfedale pro bx1360sd
I have had problems with this stereo mixer amplifier which had the symptoms of no sound output from either channel .
I opened up the unit and discovered that the amplifier was correctly amplifying my input signal up to a relay which switches the output through to the speakers .
This relay did not activate at all.
When the power switch is turned ON you should hear a click approximately 2 seconds later , if no click then there is a problem with the circuitry associated with this relay .
I traced out all the connections associated with this relay and made a circuit diagram .
The relay is a 24v relay and I will explain the way that I can see that this section of the amplifier works.
It has been designed to ;
  1. Create a slow start delay ( 2 seconds ) when the power is turned ON.
This it needed because otherwise there is a current surge and sparks from the relay turning on immediately.
  1. Thermal cutout mounted on heatsink . If the ventilation fan fails the heatsink and transistors may get too hot and the cutout will operate and cut power to the relay by going open circuit.
  2. Speaker protection from blown output transistors. There are 2 transistors q802 and q803 both 2sc1815. They are connected together emitter to emitter and collector to collector to form a differential Op amplifier I.C. If there is a blown output transistor then DC voltage will be detected by q802 and q803 and the relay will be switched OFF to protect the speakers .
Q804 turns On Q805 which turns On Q806 to activate the relay .
Voltages on transistors
Q802 and Q803 2sc1815
Base 0V Collector 12.9V Emitter 0V
Q804 2sa1015
Base 12.9V Collector 0V Emitter 15.1V
Q805 2sc1815 (driver for Q806)
Base 0V Collector 7.2V Emitter 0V
Q806 2sc1815
Base 0V at Turn ON then after 2 secs increases to 0.7V
Collector 2.8V ( transistor is activated as a switch Turned Fully ON ( saturated) to turn on the Load which is the relay .
Emitter 0V
I have replaced the following transistors to fix my amplifier q805 2sc1815 and q806 2sc1815 .If you are going to use a different type of transistor it may not work and also the lead connections of a 2sc1815 for the collector and emitter are different to those such as on a 2n2222( transposed).
Oct 15, 2010 | Audio Players & Recorders
Are 2 - 125V 5 amp fuse good enough to use just to check and see if this works...was working just fine. no wires touched..am i looking at a large problem?
Fuse rating would be written on circuit board fuse located, yet 5 amp fuse will work to test the receiver/ amplifier.
If fuse blew off again, then amplifier has problem either in power supply or amplifier output section.
Qualified Tech will fix it.
Thanks.
Dec 01, 2009 | Onkyo TX-DS595 Receiver
Manual for the NSM Prestige E160 and circuit for 76M amplifier
If you send me your details I will scan my circuit diagram for the 76M amplifier. I do not have the manual but I do have a list of the programing locations.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Jun 04, 2009 | Wurlitzer Jukebox CD Player
Leem power mixer spare part
Sep 17, 2008 | Car Audio & Video
Leem m86t power mixer amplifier
Sep 09, 2008 | Car Audio & Video
DMR-EZ47V
still need diagram for TRUTH 2031A Amplifier Thank you Eric
Mar 15, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
