Question about Nikon D200 Digital Camera with 18-200mm Lens
Prob with exposure analog...
Hi.. i own a nikon d200... n d prob is that d exposure analog keeps flashing n showing that d pic is under exposed.... how do i get it to stop flashing?? also most of my pics r underexposed evn at bigger apertures and slow shutter speeds... plz help...
  • koolkhyati Jun 25, 2008
    datz ridiculous... i juz bought dis cam 2 months bac.... i cant possibly buy a new 1...and i dunt think my prob is dat huge dat it wud cost me a bomb...
  • 48 Answers
I could tell you how to fix it but it would probably cost more than a new camera. just buy a new one.
Posted on Jun 25, 2008
Camera will not fire when the built in flash is raised.
replace bulb. if u r using external flash plz use ineternal flash also some time to keep it safe
Jan 04, 2013 | Nikon D200 Body Only Digital Camera
My Nikon D200 keeps blowing out the whites and sometimes everything in the shot. You can reshoot the same subject and everything is fine but sometimes you can get a good shot. Any suggestions?
try not using the full auto settings all the time. the auto system has a tendancy to over expose. the camera can over or under judge the lighting and make an improper exposure
Oct 25, 2010 | Nikon D200 Digital Camera
I am using a Nikon D200. When using flash I can't raise the shutter speed any higher than 1/250. It seems to be locked there and I don't know how unlock it. Please help.
That's entirely correct. 1/250th is the fastest shutter speed you can use when using flash. Many other cameras can still only use 1/60th or 1/125. It's all to do with the two curtain nature of an SLR shutter: when you release the shutter, one curtain withdraws across the frame to expose and then a second one follows behind to shut off the light source. For exposures of 1/250 or slower on your camera, the second curtain does not start to travel across until the first one has fully opened, so you have a fully open exposure frame allowing the flash to reach every part of the sensor. At faster speeds, the second curtain sets off before the first one has finished and at the highest speeds it's so close behind the first that only a narrow **** is open to the incoming light as the shutter curtains pass across the sensor. If you fire the flash at these speeds the shadow of the first or second (or both) curtains will appear on the sensor and the picture will look like a narrow horizontal band, or if using fill in flash, it will look like a bright band across the picture.
It's immaterial though as the normal exposure rules don't apply with flash: the flash duration is typically anywhere from 1/4000th to 1/50000th and in that exposure time it outputs sufficient light onto the subject to enable a photo to be captured. As the flash is the dominant light source, the ambient light captured when the shutter is open for 1/250th is insignificant unless you're making a daylight exposure and using the flash for fill in purposes.
There are some specialist SLR and flash combos which will allow the full range of shutter speeds, but they do so by firing the flash multiple times very rapidly to ensure that there is flash light present effectively continuously as the narrow exposure **** passes across the sensor.
Compact cameras have shutters which work differently and which fully expose the sensor at all shutter speeds, so in that respect they can have a far more flexible flash exposure system. Unfortunately, they ruin it by having pathetically weak built-in flashes which are only good for very short distances.
Sep 03, 2010 | Nikon Cameras
Exposure display issues
If you are looking through the camera eye piece, it will show it as an over exposed image, but it you look at the finished product (if you are shooting on Manuel which I suggest), you can still move the aperture and speed to change the final out come.
Mar 24, 2010 | Nikon N65 35mm SLR Camera
My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Jan 03, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Black flashing on screen where light is
This allows you to see where your photo is over or under exposed. It helps you see if the exposure is set right.
You can turn it on and off by moving the Up/Down/Left/Right button up or down. This will move you thorough the image data (shutter speed, aperature, file format...etc.). It should show "Highlights" on the screen when you have this selected.
Aug 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Consistent under exposure
Under exposed should be minus not plus number.
Lucky you didn't buy Canon 5D or 1D- they have focus and exposure problems.
Hope you are not using the pop flash that is on the camera. If you are, then turn off the Red Eyes Modes.
Set camera to manual mode and lower the F number(open up to half or one stop).
What studio lights are you using? Increased the light output of studio by those number and shoot like you normally do.
atdlee@netzero.com
Dec 11, 2007 | Nikon 20MM F2.8 AF NIKKOR Lens
Nikon D200 Digital Camera with 18-200mm Lens Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
