How to remove the stand
Could you tell me how i remove stand from the bottom of the television. Ihave fixed television on to the wall but the stand now looks silly so could you please tell me how to remove the stand? Many thanks
  • 4 more comments
  • Anonymous Oct 14, 2008
    trying to remove the stand
  • Anonymous Dec 23, 2008
    remove stand
  • pitch1000 Dec 24, 2008
    Trying to remove stand off my Sony Bravia KDL-v32a12u with no success. Any help?
  • Anonymous Dec 31, 2008
    i mounted my flat tv on the wall ,, but the stand is touching the wall and makes the screen looking to the ceiling, how to take it off
  • tri1 Feb 01, 2009
    Did not receive instructions with tv. need to remove stand in order to mount on wall.
  • Anonymous Feb 19, 2009
    someone please tell me how to remove the base from thr sony bravia tv
On the the sticker on the back of my SONY kdl-40xbr1, where the model number is, there is the symbol > x 18.  That means you need to remove the 18 screws on the back of the tv that have arrows next to them.  Most are around the outside but 2 were by the RCA inputs and 2 were under the cover for the computer input.
Once you remove all these screws the back will come off easily.  Remove the 4 screws holding the base on, slide it off and refasten on the back with the 18 screws.
Thats it.
Posted on Jan 31, 2009
  • 520 Answers
Look on the back of the tv. The screws holding the stand on may have arrows by them.
Posted on Jun 26, 2008
Yep, previous poster exactly right. It's deceiving, because it looks like the bottom screw on the stand alone could do it, but it's really the screws with the arrows pointed at them.
Posted on Aug 02, 2008
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Cannot Remove Stand From TV
There should be two screws on the back of the television toward the bottom. If you remove those you should be able to slide out the stand for wall mounting. But please be careful. If you damage the television attempting this then you can lose your warranty. The manufacturer recommends professional installation only for mounting your television to the wall. Good luck. :)
Jun 20, 2008 | RCA Televison & Video
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
Televison & Video Logo
1,683 people viewed this question
Top Televison & Video Experts
