Question about Microsoft Xbox 360 Console
UPS for X box
Hi i just got a new x box and i have a n inverter backup at my home but whats happening when power goes off the box started showing 3 red lights and its off?
My dealer suggest me with a 1 KV UPS so i got it yesterday only.
Is it the right solutions.
  • 24 Answers
Well if im to be very honest hes was wrong so go to your dealer and give him a BJ, i recommend you buy a new one.
Posted on Jun 25, 2008
My inventer 100w sukam is not loading of one cfl 15 wats . Ichanged many battery of 12v ,7.2 ah but they showing low battery what is the problam.
What happens with no load? WHat IS the battery voltage exactly?
Many inverters/UPS wont start with uncharged batteries to protect them.
Oct 23, 2014 | Computers & Internet
My inverted goes to battery mode even when mains supply is ok.then it will come back to normal mode again and run of mains.what is the solution
If this happens repeatedly and doesn't stop for 10-30 minutes... then you have a bad inverter. Price of repair compared to just buying a new one are about the same.
Remember, it's not just sags in current that activate the UPS, it's also spikes... and if you're getting many of those in a short time frame then the UPS is doing it's job.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go
to our website: http://psihq.com/
Aug 27, 2013 | Compaq 204015-001 - UPS T700 - UPS - 700...
GE LP33 UPS inverter failed to start
Dear Yared,
Did you try to give the UPS some time to recharge the batteries?
Seems like the batteries have reached their cut-off voltage and are not supplying enough voltage to the inverter.
Normally the dc boos circuit of the UPS will supply voltage to the DC BUS so maybe the problem can be found in the dc boost circuit or BUS if recharging the batteries is not helping.
Let me know.
Best Regards,
Ron
Jan 22, 2013 | MGE Computers & Internet
Yesterday and today one of our Smart-UPS 1400 powered off and 2 of our servers along with it. What would cause this?
may be power to the UPS went off or was not within permissible limits, hence the ups run on batteries until they were completely discharged, the servers went off because they are supplied by this ups. check the power supply to this ups, somebody could be switching it off accidentally. try to sitch the inpu power to the ups to see whether the batteries are okey
Dec 15, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
How to set up Power backup using Batteries and an Inverter
Having only two batteries and an inverter is not an UPS (uninterrupted power supply) does not make a backup power system.
How are the batteries charged up and maintained?
What is the output voltage from the inverter?
Does this voltage suit the Netgear wireless router?
I suggest you get a proper UPS and connect the Netgear power adapter to the UPS. There are small UPS units available 350VA which will suit your needs.
I use a larger UPS from APC for my computer and my wireless router and found the unit very reliable.
Check out APC WEB site - click on this link - then your country and select back-UPS ES for home computers :-
www.apc.com
Nov 12, 2009 | NetGear WGR614 Wireless Router
My ups is switching off itself immediately the mains goes off.the battery is okay with 13v.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and enviromental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only a float voltage and a true indication of the battery voltage needs the batteries to be tested under a load. there maybe one battery that is faulty and causing the whole battery system to fail.
These lower powered and cheaper KVA type UPS are switch over types (when the mains fail, the UPS switches over to the inverter in milli-seconds to supply mains power). It is a possibility the inverter circuit is faulty and when the mains power fails the inverter does not switch over.
The true UPS type are usually the higher KVA units (over 1500 KVA units) that converts mains power continuously via the inverter circuit. The mains power charges the batteries and the inverter drawing power from continuously from the batteries (therefore there is no switch over time lag from the mains to the battery.
Sep 25, 2009 | MGE Pulsar Ellipse 800 (89363) UPS System
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
LCD shows Low O/P V
Fault: Low Ouput Voltage
Cause: Surge Taken by load / Short Circuit on load / Fault in inverter
Remedy: Remove load and restart UPS / Try a different load / Repair or swap out
If you need spares or price for repair contact Eaton Power Quality Ltd - the new name for Powerware - 01753 608700
Dec 15, 2008 | Powerware 9120 UPS System
Not working
Some UPS have "Battery backup" and "Surge only" outlets. I don't know if it is the case for your model. The "Surge only" outlets are not connected to the battery and will go off during a power outage. Make sure that the equipement that need to keep running during the outage are connected to the "Battery backup".
Important: Never connect a laser printer to the "Battery backup" outlets because to power draw is just too high.
Have you made sure that the battery is connected inside the UPS? (If the battery is user-replacable)
You may do a simple experiment. Connect you UPS you a wall outlet and plug a conventionnal lamp to a battery backup outlet. Then, unplug the UPS from the wall. If the light goes off, then you may have a problem with your UPS.
Apr 19, 2008 | Belkin Home Office 350VA (f6h350-usb-dl)...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
