2621217005 for a Denon DRA-1025RA receiver
Hi Dave,
"Since my solution was rejected by you, I guess you also do not want my help contacting Denon tech support."
I am still trying to figure out how the FixYa website works.
I keep receiving e-mail messages that say "There is a new Solution for ..." or "There is a new Comment for ..." but I do not understand how to see them (the e-mail I receive is text based and has no obvious links or website addresses).
Is there an easy way for me to see all the Solutions and Comments at the same time?
Or to cycle through them one at a time without 'rejecting' any of them?
I do not yet have a solid lead on a 2621217005 and appreciate all the help this site's users and gurus have provided.
Sorry if I am misunderstanding the site and giving the wrong impression from the options I am clicking,
DonMoody
    President:
  • 624 Answers
That's fine DonMoody, it can be a little confusing at times. The options are very clearly stated as to what they really mean. Rejecting a solution means, the solution does not help you, or you tried and it did not work, something like that.
I am kinda new here to, about a week. Be very careful who you listen to here, some "guru"'s are not what they seem. But I am sure you can tell by some answers you get.
Is that unit an older stereo reciever? I recognize the "DRA" but not the 1025RA part.
What is tis part you need, sometimes a generic part will do the trick. Depends on just what the generic number is. That should be the number that is printed right on the part if it is an IC
I will see what I can come up with when I get to work in about 6 hours. I go to the doctors in a few minutes and then I go to work.
let's see if we can't solve this for you. If I go thru my sources and can not get the part, it is just not available. sometimes that happens, even with newer equipment.
Posted on Jun 25, 2008
Hi i have a denon dra 685 and when i hook up the speakers i barley get a sound out of it im thinking one of the channels may be out but is there a way i can reset the system as i was given the amp
Hello. My name is Dave. Does this unit have a tape monitor button? If it does, you probably have it switched on. Make sure you turn down your volume before turning the tape monitor off. If not a tape monitor, it may may another switched path that you have engaged. Same fix as above.
Sep 30, 2012 | Denon DRA-685 Receiver
I need a 2621217005 for a Denon DRA-1025RA receiver.
http://www.vancebaldwin.com/products/?DEN2621217005
Jun 24, 2008 | Denon Audio Players & Recorders
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Dec 16, 2008 | Denon DRA-397
I am guessing the system IC is the microprocessor. Normally that is what it is.
Most microprocessors do not have the complete part number on the IC. A letter or two will be missing from the beginning and also from the end of the number on the IC. Many times technicians will be able to figure out what those missing numbers/letters should be, just from experience dealing with IC's like this. Many have common letters at the beginning like "UPD" or "UPC" for example.
That would be unfortunate if so. It is really hard to find old microprocessors, and they rarely make subs for them.
To be certain that the system IC is indeed the part that will fix the unit, can you tell me how you came to that conclusion.
I am about as close as you can come to being considered an expert on troubleshooting the microprocessor and I may be able to help you ensure that it is the part you really need. I have seen on many occasions when a technician replaces the micro and the unit still has the same problem. And I am talking about well trained technicians, not some dummy. It has happened to me on several occasions. The micro is a very hard component to troubleshoot with certainty. It could have a supply voltage missing, a shorted cap connected to it, an open resistor or a resistor that is just out of tolerance connected to it.
Is this IC a surface mount IC, or do the pins go thru the board?
Surface mount IC's are very difficult to replace, without excellent soldering skills you can damage the IC or leave solder bridges and without a high powered magnifier you can't see them.
since this is an old unit, it probably has an IC with the pins thru the board. In a dual inline package. Meaning that the IC is long and rectanglular with pins on both the long sides. Those are easy enough to replace with just decent soldering skills.
Many times with older equipment the micro can have the solder reflowed and it will fix the unit. After so many years, the solder will start to change in it's chemical make-up a little and not conduct very good. It gets heat stressed and you can tell because it will look a little "grainey" and not be nice and shiny.
All micros have a crystal that clocks the cycles of the micro, and you would need a O-scope to check it. Two of the 3 pins of the crystal go to the micro and have a sine wave at the proper frequency. You can also check the voltage on those pins and most measure at about 2.5 volts plus or minus a little. Ref #'s for a crystal start with an "X" like "X201" for example.
Since you must have the service manual for this unit (you have the Denon part number), you can check the schematic and find the crystal and see the frequency there.
I would like to tell you how to handle those emails, but I have never been an asker of questions and I am new here, so I don't really know the right answers on that issue. But I can say that you should only reject the solutions that you are sure are of no help to you. And when you decide to wrap things up on FixYa you should give a "FixYa" rating to the person who gave you the information that solved your problem, or if your problem can not be solved , the person who best helped you make that decison that the unit can not be repaired. Otherwise, Fixya will not give any of the "experts" the couple of dollars they are all trying to make for answering your question. You really should reject answers that just don't make sense to you.
In your case, you are getting some valid answers to where you can find that part, if available, and if you get the same answers from many different people, you should reward the first person who gave you that answer. But do not give a rating to anybody until you are sure you have finished using FixYa for this particular question. It is OK not to reject any answers, just make sure when you are finished, you give somebody credit for solving your problem, whether it results in you finding your part, or finding out you can not get it anywhere. I have yet to get credit for any of my answers on the premium solutions even though I have given people the correct answer, they just did not like the answer. But it doesn't change the fact that I was right about the problem they had. Sometimes the correct answer is not always something the person asking the question can use to fix the problem they are having. Mostly when it means they must take the unit to a repair center because the problem is not something that can be fixed by them. This is not to say that you can not fix this problem, I assume that you have some knowledge of electronics since you were able to get the correct part number that would only be listed in a service manual.
Give me a few hours and I will let you know if that part is available anywhere, in the mean time, lets make sure it really is the part you need. it may be something you will need to find on ebay or something from another one of these same unit's with a different problem.
I work with another Tech who has a saying "it's never the micro" and if you replace the micro and it doesn't fix it he says "at least you know what it isn't"
He is right more times than not.
Jun 25, 2008 | Audio Players & Recorders
Denon Part# 2621217005 for DRA-1025
Sorry after I posted I checked; every distributor that I could find it is listed as unavailable. I even went as far as looking for the type of part it was to see if I could get one with the same specs. I spent a good hour looking for it but it looks like your best bet is going to be a non functioning used unit.
Jun 24, 2008 | Audio Players & Recorders
Denon dra 1025ra seems to be stuck in standby mode. How do I release standby to power up
Unplug receiver from AC outlet, and plug back in. The power reset should clear up the problem.
May 18, 2008 | Denon Audio Players & Recorders
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
156 people viewed this question
 Grubhead
Grubhead
