Question about VIA Computers & Internet
SDRAM REPLACEMENT I HAVE MY P3 650MHZ PC 128MB SDRAM PC100, I UPGRADED MY OS TO XP. I WANTED TO UPGRADE MY MEMORY TO 256MB, THE PROBLEM IS NO MORE AVAILABLE 128MB SDRAM PC100. THE ONLY AVAILABLE IS SDRAM 256MB PC133. IS IT COMPATIBLE IF I REPLACE MY PC 100 SDRAM WITH MY PC133 SDRAM. BY THE WAY MY MOTHER BOARD IS SYS. MODEL: VIA TECH INC., SYS MODEL: VT82C692BX. THANKS I HOPE YOU CAN HELP ME.
No not compatible! Your system is obsolete, almost impossible to upgrade anything. Socket 478, P4 cpu stuff, is the oldest system with any chance of upgrading or maintenance.Get a 'barebones' new system for $250/300 from the Inet [ ebay or simillar ]/ You will then get some value from the cost of the windows Xp if it is the full version or alternatively you have both original OS disc and windows Xp ugrade disc. If what you buy has an IDE hard drive. you can also install your current hard drive too, keeping what you have on it, as a slave drive after you have put your OS on your new machine plus any cd or dvd on your old machine.All this is simple and within widows framework and tools, no tech skill needed, just a screwdriver and a manual with your new barebones motherboard. Plug the old ide drive into the right socket from the conncecting braid, set the jumpers as per hard drive diagram on the back plate on both drives. One master, one slave.Remember NOT to format your old drive/ LOL/
Posted on Jun 26, 2008
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Whats my sdram capacity
HP Pavilion 9694C memory upgrade specification, Pavilion 9694C maximum memory, memory speed, and memory upgrade options. Upgrade memory on HP Pavilion 9694C upto a maximum of 256 MB
PC100/133 SDRAM DIMMs, with maximum 128MB per slot in 2 memory slots. The HP Pavilion 9694C takes the PC100/133 SDRAM DIMMs Memory Type.
Hope that helps.
Feb 16, 2011 | HP Pavilion 9694C PC Desktop
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
I have a Tecra 8200 bought as used fitted with 256MB of ram. If I buy an extra 256MB which brings the total to the maximum allowed of 512MB is it likely that I will need to upgrade the bios to allow the...
This laptop came with 128mb ram, you can safely install 2 sticks of 256mb for a maximum of 512mb with no bios update.
You need pc100 sodimms.
Amazon or ebay will be the best bet as this memory is expensive now from a retailer.
I found 256mb sticks for under $10 buy it now on ebay http://cgi.ebay.co.uk/256MB-SODIMM-PC100-SDRAM-256-MB-PC-100-LAPTOP-144-Pin-/190411543153?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item2c55699271
Jul 08, 2010 | Toshiba Tecra 8200 Notebook
What steps are needed to upgrade my memory. I have a etower667ir with ramsd64mpc. I want to install 2 128mb sdram dimm pc100. what do I need to do?
First download a system analyzer fromwww.belarc.com and use it to check what is the maximum Ram that it can accommodate. If it will take just make sure you-get Non-parity ram when you buy the sticks. please note that SDram is more expensive that DDRam, but cannot be substituted.
Jan 06, 2010 | E-Machines etower 667ir PC Desktop
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
UpGrade
download cpuz it will tell your specs
Oct 18, 2008 | E-Machines eMachines Desktop PC
Memory Upgrade
64MB HP Pavilion 168-pin PC100 SDRAM DIMM
128MB HP Pavilion 168-pin PC100 SDRAM DIMM
Dec 10, 2007 | Computers & Internet
Computers & Internet Logo
157 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
