Question about Kyocera FS-3900DN Laser Printer
Kyo 3900 printer
Do you know how to reset maintenance request on the above printer, many thanks,
Hayden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Menu button scroll down to other than down to service than down to maintenance press enter after you fit the maintenance kit and the developer up.
Posted on Jun 27, 2008
I need the instructions for Hayden 3651
Hi Paul,
I have the wiring diagram image for you. Hope it helps.
Apr 24, 2014 | Hayden Automotive 3651:Hayden Electric Fan...
Parts inside in my printer are near the end of their service life
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is:
1. Replace the Waste Ink Pad/Pads with a new one/ones (many people ignore this one, and they just follow #2)
2) Reset the Internal Waste Ink Pad Counter by using SSC Utility
Download from this site http://www.ssclg.com/epsone.shtml and follow instructions.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
General error
general error are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you. Or Call or email Epson Tech Support.
If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Jan 12, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Hp deskjet 3900 installer for windows 7
Click here You can download hp deskjet 3900 series driver from below link. Let me know if you need further assistance. Thanks for using FixYa.
Nov 12, 2010 | Office Equipment & Supplies
I need a Hayden Superpack Deluxe owners manual so I can change the belt
Hi There,
Actually Hayden uses Panasonic to make all of their power nozzles. Replacing the belt on your Hayden is the identical process to replacing the belt on Panasonic canisters. Kenmore canisters also use Panasonic power nozzles, it's the same process with these.
There is also a power nozzle overload switch on the top of the power nozzle that will shut down if anything is vacuumed up that causes stress on the belt. Try pushing this reset switch before opening up the power nozzle to install a belt. It may be something as simple as a reset switch.
If this doesn't work, here's a link to a repair that I've posted on Fixya on how to replace the belt on a Kenmore canister power nozzle, the process will be identical to your Hayden power nozzle.
http://www.fixya.com/support/t4563318-change_belt_sears_vacuum
Hopefully this helped you. Please be so kind and rate the repair, or leave feedback for the fixya community.
Thank you,
Chris
May 22, 2010 | Hayden Industries SuperVac 6000 Central...
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Hayden Supervac 3600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11860&thid=808510
Posted by kdm0 on Jul 20, 2008
Hi, I have a Hayden Supervac 3600 central vac system in a house I just purchased. The Amber light indicating that it needs regular maintenance is on. I have cleaned and serviced the motor, everything is fine and suction is well. How do I reset the service light? The reset button seems to do nothing. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I heard of this happening before and you need to refer to the owner’s manual and or to contact the factory or manufacturer of which I will provide to you @ the end of this question. There may be some type of rely switch or board that might need replacing but check with the factory. If you need further help please refer to a local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.haydenvac.com/company/company.html
Customer Service 1-800-461-5300
Company Phone # 1-705-726-3361
Company Fax 3 1-705-726-2186
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hayden Industries SuperVac 3600 Central...
I have a cx6400 Inkjet printer. I just received an printer error message that there are parts inside my printer that are at the end of their service life, see printer documentation. The documentation...
This is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error
2) Reset the Internal Waste Ink Pad Counter by using this utility
May 08, 2008 | Office Equipment & Supplies
Kyocera FS-3900DN Laser Printer Logo
767 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
