SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
SOURCE: taylor scales model 7314 lithium scale
Have you tried to email Taylor Customer Help and Support?
They are very useful. They can guide you through problems, provide you with instructions and might send the user manual via email.
I hope you get this fixed. Scales are very tricky!
SOURCE: I can't find the battery number to replace my
yes call the manufacutere or go to the store where you purchased it from and they can supply you with a the proper company and phone number
SOURCE: How can i replace battery in Taylor lithium scale
turn it over and open the battery compartment. CR2032 battery
