Question about Sony Handycam DCR-DVD100 DVD Camcorder
Disc Access error
Error: C:13:02
  • Nikhilb2008 Oct 02, 2008
    I have a DCR DVD 803E. I have the same 13:02 error. I simply HAVE to get the data on this DVD. What are my options?
Place a readable disc in the camera and record a short scene. Turn the camcorder off Replace your error disc in the camcorder and turn the camera back on to the play/ edit mode
Drgadgt
Posted on Nov 15, 2008
That did not work. I have a sony hdr-ux7. Anything else I could try?
Posted on Sep 08, 2008
  • 10,594 Answers
Clean the optical lens in camera with nice quality soft cotton swab.
Posted on Jun 25, 2008
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Every time I turn my sony on, it reads disc error,
your disc inserted is the problem change another one.
Jan 21, 2010 | Sony Handycam DCR-DVD101 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Disc error! remove disc
actually ur lens got weak and it is unable to prepare the disc for writing if u can see ur lens u can try cleaning it with soft cloth very soft or u can buy a dvd cleaning kit for ur camera it will help other wise u have to change ur lens
pls rate me if it helps
Dec 16, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Jul 10, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
DISC ERROR
Clean optical lens (where you put disc) of your camera with soft cotton swab. Hope problem will be solved.
Jun 22, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Disc Error: Remove Disc
YOU PLZ CONTACT WITH NEAREST SERVICE CENTER.
Nov 07, 2007 | Sony Handycam DCR-DVD103 DVD Camcorder
Sony Handycam DCR-DVD100 DVD Camcorder Logo
480 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
