Question about Roper RES7646KQ Electric Dryer
Power supply color codes
Hi! whats the color codes of power supply?
  • wulffharley Jul 27, 2008
    soes this have a three or four prong cord
  • Roper Master
  • 8,220 Answers
Either one. Just get the middle in the middle(neutral) and either hot on either side. Green wire to ground. How simple is that. want photo?
3 wire:
Posted on Dec 31, 2008
Color coded travel adaptor. Not sure color matching Germany
Don't know the color codes, but It has two 4.8mm round contacts on 19mm centres and two grounding clips on the sides of the connector body for Germany (Type C Plug).
Jun 11, 2010 | Franzus Grounded Adapter Plug Power...
How do I replace the power supply board on my viesonic N2751?
hi! to replace the power supply you need to remove the back cover of your tv..once it is remove you can see the power supply...all its wirings are detatchable with connectors...and color coded be very carefull not to interchange them...
good luck! hope this could help you...
your rate is important to this help tnx.
Apr 24, 2010 | ViewSonic N2751W 27 in. LCD Television
I need a wiring diagram and or a color code chart for the wires and plugs coming out of a "Power Tronic" switching power supply model SK-4145DE. 145 watt power supply. Thanks for your help.
Many power supplies have a chart on the side of the case.
Here are the wire colors for an ATX type supply:
RED +5, YELLOW +12, White -5, Blue -12, ORANGE +3.3,
PURPLE +5VSB, GREEN Power On, BLACK -Gnd (common).
Feb 14, 2010 | Power Tronic PowerTronic 145W Switching...
Thers 4 wires to connect 1 red 1 black 1 white and
Well, if there are no color lights on this strobe effect, a fairly standard color code for AC is Black is HOT White is Neutral, no insulation is ground and Red would power your strobe ( I Think )., I would hate to misinform you. Is this an AC powered strobe? Like when you wire up a ceiling fan you have the same color code. I'm sorry I can't help you further, and messing with live AC can be unsettling.
Nov 03, 2009 | Peripheral Enhancements EDGE Tech Corp...
Dell Demension XPS B866 N232 motherboard power pin assignments
dont take any risk with power supply. purchase a new compatible power supply to solve your prob...
good luck
Jun 12, 2009 | Intel Motherboard
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Jun 13, 2008 | Roper RES7646KQ Electric Dryer
Power supply crow bar
Hi, if your computers manual tells you that you have a power supply fault you need to replace the power supply or take the computer to a repair shop and have them do it for you. Regards mistyman
Sep 22, 2007 | Compaq (176763001) 120-Watt Power Supply
Type of power supply and what where is the +/- 5v or color coding for the 4 pin connector?
Dhen: This monitor uses a special Power Adapter as shown... Also the Pin designation is from the NOTCHED PART BEING ON TOP: NOTCH U +V O O +V GND O O GND SithPitt
Jul 04, 2007 | HP L1520 15" LCD Monitor
Roper RES7646KQ Electric Dryer Logo
575 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
