Gas heater not working...no flow of gas - Heating & Cooling
  • bosskcchiefs Dec 14, 2008
    carrier heater will not come on
  • jdaxc Dec 26, 2008
    My gas heater just stopped working, when it had worked prevously. Could this have anything to do with the thermostat?
Gas heater is not working;
flow gas thru..YES; ain't flame in all unit made it by carrier
Posted on Oct 17, 2008
Gas doesn't seem to be flowing
I purchased this heater second hand - I have fitted a brand new regulator and gas hose - gas is flowing as far as the burner assembly but I cant hear or smell gas flowing to the pilot or the main burner. Is there a section of pipe between the gas hose and the burner that could be missing? Does anyone have a diagram of all the parts - exploded view?
May 30, 2014 | Stainless Garden Sun Steel Propane Patio...
No gas flow patio heater
Check thermal couplerxxxxxxxxxxxxx
May 24, 2014 | Heating & Cooling
I have a giordano heater that won't light. There is a narrow pipe that diverts gas to the igniter spark. The pipe is capped by a small metal regulator with what looks like a very small hole in it to...
Never drill or try to make the pilot hole larger, this will cause a large flame that cannot be controlled. Check the main parts, first see if you have a spark, next check for leaks, to see how to do a leakage test see patio heater problem solving page. If no leak try changing the thermocouple, these will wear out and can last up to 6 years. Also check the electromagnetic valve that sits inside the gas control valve and if fitted check the tilt switch works. The tilt switch can be shorted out to see if it works.
Aug 03, 2011 | Stainless Garden Sun Steel Propane Patio...
One side glows like a champ. The other side, dedicated for High setting, pooffs when I turn it to high, then kind of fickers and barely glows. I have a fuel filter and a six foot hose off of a 20#...
dirt , foriegn material,spider web in gas feed line to the right side ceramic element of mr heater big buddy. take plastic back of heater
off, many #1 philips or smaller screws. find large air induction holes
in gas feed line to right side ceramic element and blow out with compressed air and fine tiped /straw tipped air blow gun.
straw tipped air blow gun is a better tool for this.
reassemble & try lit mr heater again.
If it dont work after air blow gun the gas feed tube, you didnt get the gas feed tube cleaned out ,***** & span (something still in there ) and will need to disassemble the gas feed tube and inspect for foreign material blocking the gas flow.
If this dont work,need to take the gas feed line off the gas valve attached to Mr. heater red knob. red knob just pulls straight out, might need pliers to grab red knob.
check gas valve output for dirt etc that stop gas from getting through. check inside the gas line to the ceramic burner for dirt,
foriegn material- that stop gas from flowing through strong.
any stopage of gas flow , even a slight stopage or dirverting of the gas flow, spider web is common, will stop ceramic element from burning properly.
needs to be clean ,like a carburator.
Dec 27, 2010 | Mr. Heater Big Buddy Heater
I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
Nov 29, 2010 | Desa International GWRP16 16,000BTU LP Gas...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Pilot light will stay lit as long as i hold down the knob, but when knob released, light goes out....... i have a wall mount model# GWRN30t
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
Oct 05, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
My ranai tankless heater is not working
Check the electrical supply to the unit but my guess would be an issue with the water flow sensor.
Mar 16, 2009 | Rinnai Water Heaters
Heating & Cooling Logo
500 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
