Question about Dayton Heating & Cooling
How to connecting the Dayton Motor,1 Hp,General - 6K562 Connection Diagrams
    Novelist:
    Champion:
  • 230 Answers
Grainger sells these units. They should be able to provide the diagrams that you need.
Posted on Jun 25, 2008
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Need the size of the run start capacitor for a Dayton 1/2 HP motor #5K529A. Also where can I get one along with the cap cover for the motor and a key for the shaft?
all those items you can easily obtain right from the Home of Dayton , ( Grainger.com) as Dayton is there stock brand
and with there huge system of local stores too , im betting there's one within a short ride to it near you .
Oct 26, 2015 | Dayton Dryers
115v electrical hookup for dayton motor 1TMY6
Dayton manufacturing is owned by WW Grainger
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1TMY6&op=search&Ntt=1TMY6&N=0&GlobalSearch=true&sst=subset
Contact Grainger 1-800-323-0600
They will have wiring information for each of their products.
The wiring diagram should appear on side of unit.
This 1.5 Hp motor can be wired for 115 or 230 volts
My AO Smith manual would not be specific to your motor.
With AO Smith 115-230V, there are one set of wiring terminals for incoming wires from breaker box. The other wires connect to terminals.
Copy following illustration link:
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Wire and breaker size:
For 120Volt, use 20 amp breaker and 12 gauge wire up to 25 feet.
Over 25 feet up to 100 feet, use 30 amp breaker and 10 gauge wire.
100-150 feet use 8 gauge wire and 40 amp breaker.
150-200 feet use 6 gauge wire and 50 Amp breaker.
Sep 28, 2012 | Dayton Permanent Split Capacitor Motor Fan
What the codes
You want delay fuse instead of fast-acting fuse. Look for delay on product description.
Since the motor has a high amp draw when first starting, then that means surge of heat traveling over wire.
Fuse trips when sensing heat.
Delay fuse will accept high heat for longer period of time before tripping.
You have 1 Hp 6K321 motor from WW Grainger. You can contact grainger.
http://www.grainger.com/Grainger/DAYTON-General-Purpose-Motor-6K321?Pid=search
I recommend that you use 12 gauge wire and 20 amp fuse. Over-sizing wire will save heat loss and prevent damage to motor, and heat damage fuse box.
If you use smaller 14 gauge wire and 15 amp fuse, the motor will heat the wire, especially if length of wire is longer than 100 feet from fuse.
The motor has thermal protection, so motor is not overheating.
The wire is overheating.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Sep 27, 2012 | Dryers
Dayton model 6k754m 1 hp motor compressor duty dual voltage turns ccw and needs to turn cw leed t2 &t3 need connection diagram.
Grainger parts can send you the diagram if it is missing or illedgible from the motor nameplate. Contact them at http://www.grainger.com/Grainger/RP_cont.jsp or 1-800-323-0620.
John
Aug 23, 2011 | Dayton Dryers
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Dayton 1/2 hp dual voltage motor overheats (mtr #6k79). Replaced original motor with same motor overheats in 10 -30 minutes. White lead to #4 terminal, black lead to #1 terminal, ground to casing.
Wiring would be for low voltage 1-3, 4-2. L1 feeds 1-3 and L2 feeds
4-2. For high voltage L1 feeds 1 and L2 feeds 4 with the 2-3 terminals linked by wire or bus bar.
Jul 23, 2008 | Dayton Heating & Cooling
Heating & Cooling Logo
351 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
