Question about Motorola Mobility RAZR V3xx Cellular Phone
Rubber screw covers
How are you, mate.
Just read your post on http://www.fixya.com/support/t611175-rubber_parts_needed
The same thing happened to me and I can't find it on e-Bay, and the website given does not have them in grey.
So I was wondering if it would be possible for you to send some to me? I live in Perth, Western Australia
  • Anonymous Sep 20, 2008
    i lost my rubbers too
    Brigadier General:
  • 7,752 Answers
Try the motorola website
Posted on Aug 18, 2008
How to I remove rubber boot and change blade clamp assembly on my Ridgid R864 cordless reciprocating saw
Frank remove lever,pin and shoe, and slide/pry rubber boot off, Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ridgid R864 Cordless Reciprocating Saw Parts
How do remove the rubber boot which covers the front of the Rigid R3002...
http://www.homedepot.com/catalog/pdfimages/5e/5eda0284-2196-4e9f-80f7-73264ab9f6d3.pdf
Apr 22, 2016 | Ridgid Saws
Remove rubber boot ryobi rj150v
Ryobi removal Reciprocating Saws Questions & Answers ...
www.fixya.com > Forum > Tags > removal > Reciprocating Saws
We have a ryobi rj150v model reciprocating saw (older model) which needs the ... How do I remove the rubber boot which covers the front of the Rigid R3002 ...
How do I remove the rubber boot which covers the front of ...
www.fixya.com/.../t16652505-remove_rubber_boot_covers_front_rigid
Feb 18, 2013 - How do I remove the rubber boot which covers the front of the Rigid R3002 recip. saw? - Ryobi Ridgid R3002 Fuego Orbital question. ... We have a ryobi rj150v model reciprocating saw · Ryobi Reciprocating Saws · 1 Answer ...
[PDF]operator's manual reciprocating saw rj150v-02 - Gar
Nov 26, 2015 | Ryobi Saws
Asus laptop manuel
This is also in respect to your previous problem stated;
http://www.fixya.com/support/t12161144-screen_cover_off
It is also in regards to an Asus N50Vn series of Netbook PC.
A) Remove ALL power. Remove the AC adapter (Charger) and Battery.
If memory serves;
B) There are 6 synthetic rubber screw covers.
4 across the top, 2 on the bottom in the corners.
I use a computer pick, and gently pry them off. (Lift up on one side) They have a type of rubber cement on them, and if careful, can be reused.
Place them on a clean surface.
(Yes. They like to stick to the tool, and your fingers)
Underneath the 6 screw covers are 6 Philips head screws.
Remove them.
(Note*
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
Do Not mix them up)
The thin plastic frame in front of the LCD screen is the LCD Bezel.
Resembles a picture frame.
Remove it.
The outside edges of the Bezel have plastic tabs. These mate with plastic latches in the inside edges, of the Display Cover.
This video will help with the Display Bezel removal,
http://www.youtube.com/watch?v=o7vSFvHphxM
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) can be a CCFL, or a series of LED's.
From what I gather the Asus N50VN series uses LED's.
I don't have the exact model number to see if a screen Inverter is offered, or it is included in the purchase of the replacement LCD screen.
(To me, would indicate the screen Inverter is an integral part of the LCD screen assembly, for certain N50VN models )
Regards,
joecoolvette
Mar 25, 2012 | ASUS N50Vn Notebook
On a 1998 ford contour lx 4cyl engine vin 3, how do you replace the spark plug rubber seals in the head? and whats a part number if you know of one?
to do this you must remove the valve cover to get these seals out. since you have to remove the valve cover you may want to look for the whole kit to do this. it will come with new seals for tubes and for the valve cover itself. i dont have a part number but your local auto parts store should be able to get you what you need if you let them know what you are trying to accomplish.
Mar 08, 2011 | 1998 Ford Contour
Where can i buy parts for mag light 3d size flashlight , the parts that i need is a switch and rubber cap .... thanks
Hi and welcome to FixYa, I am Kelly. Please see this link for the parts you need:
http://www.maglite.com/anatomy_spare_D.asp
Rubber cap is item 7 The barrell with switch is item 6. (mouse over the item numbers and the part number is on the right. If you order the barrell with switch you probably do not need the rubber cap.
The phone number contact page is here:
http://www.maglite.com/spareparts.asp
They may be able to tell you a retailer that sells spares close to you. For sure they can get you the parts you need.
Thanks for choosing FixYa,
Kelly
Dec 11, 2010 | MagLite Mag-Lite& Flashlight
Heavy mold build up around rubber boot inside and out. clothes smell moldy when taken from finished cycle kenmore elite he4t model...
The following link can give you some advice on common causes of front loader washer odors and some preventive measures you can take to keep them from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most common causes of persistent odors comes from not leaving the door OPEN between washes. The manufacturer recommends this to allow the wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL. Leaving the door open will NOT make this water evaporate, but will allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the rubber door bellow and/or drain pump. It is recommended that you pull back the rubber folds in the door bellow (gray rubber seal) and check for dirt, debris or small articles of clothing that may have become trapped there. Socks are a common thing that become trapped, and if left for a long period of time, become stagnant. The drain pump reservoir is another common place for things to collect and become stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
You can use use a 50/50 mix of bleach and water to clean the door bellow thoroughly with a scrubbing pad to get rid of mold and mildew. Use the green kitchen type scrub pads as they are not as abrasive. Do not use steel wool. If the mold becomes permiated in the rubber and will not come off, you will need to replace the bellow to get rid of it. The following link explains how: http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load Replacement parts (if required) can be purchased from any of the following websites: searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
All these are preventive measures that can drastically prevent odors, mold and mildew. Read through the advice given and post back and let me kow if you require additional assistance. I hope you find this information helpful.
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
Change boot
If you're referring to the door bellow (gray rubber seal), the following link explains step-by-step how to access and replace one:
Replacement parts (if required) can be found at any of the following websites:
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites also have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
Read through the link provided and if you have questions, please post back and let me know. I hope this helps you.
Jun 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
FEEDING PROBLEMS FROM PAPER TRAY
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist PhillyCopiers.com 215 364 3774
Apr 19, 2009 | Brother MFC-7820N Laser Printer
Motorola Mobility RAZR V3xx Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
