Question about HP Compaq nc6000 Notebook
Compaq NC6000 would boot up once in a while, would die after a few minutes......
Dear Mr Worldvet,
Thank you for your response to the problem I posted. Before I got an answer from you, I have started looking up a Compaq service manual and had actually taken the notebook apart. I have taken out the keyboard and the metal plate underneath. Therefore I am not able to proceed with the F2 or F10 test that you mentioned. However, I could tell you that I could physically see the fan come on every time I hit the power key. Of course, sometimes the three L.E.D. s come on too and the system boots to Windows XP. I was able to run a slide show out out "My Pictures" for a few hours (with no keyboard) till I stop the unit. Yet sometimes, I will see the fan comes on for a few seconds when I hit the power switch, then nothing happens. Quite disappointing. So, the motherboard seems to working sometimes. The overheating is probably not the culprit. The fan does come on. I believe the RAMs are still O.K..
Any ideas ???
Thanks again for your input.
Rick Shum.
  • Anonymous Jun 30, 2008
    same deal laptop wont start most times
    then when it does it works perfectly, as long as i leave it on, it wont go into standby but it will sometimes restart
    done virus and spyware scans and firewall is on,
    why do i think its a virus, it only just started doing it after three years.
    when i try to reinstall the root certificates the computer locks same if i do scandisk with automaticly fix system errors, probably should get another computer.
    anyway im curious on the hp site the say take battery out and hit the reset inside the computer.
  • tinygill69 Nov 02, 2008
    i cant get my laptop to power up onto anything the fan comes on then 2min later it shuts off again ive got it running off the mains lead as i find the batteries are load rubbish ive had nothing but problems since i bought this laptop of ebay.:(
  • 408 Answers
If you go into the laptop and tighten the screw " very tightly" that connects the fan to the motherboard then use something to to move the cooling pipe "up",a little ,away from the ac jack connector on the motherboard then your grounding problem will stop.Most problems ,not all, that the nc6000s have are ground/connection related.Sometimes though it is a solder problem with the MAX chip where heat has caused cracks in the solder and causes connection problems because of flexing from the display hinges at the motherboard.In that case the solder would need to use hot air to carefully reflow the solder solid to regain a good connection.I would first try to regain ground by doing what i suggested in the beginning of this
Posted on May 16, 2011
  • 859 Answers
The fan will go off if cooling is not needed as the CPU cools down, and then go on. There is a thermal sensor underneath the CPU. That sensor can fail and no matter what the board is going to shut down, working fan or not.
Did you notice a collection of dust, lint or other debris on or in the fan? This might affect the cooling ability.
Otherwise there are a lot of reasons that XP will hang. Many of these in tower PCs are related to power supplies.
If you're using an external power supply with batteries installed to rule out one thing I'd suggest removing the external power supply and run on batteries and time how long you can work in the desktop. Once the batteries drain, if this is very shortly, reattach the external power supply and see if XP hangs up sooner than usual. If this is the case, it means the regulator on the battery that tells the laptop when to charge and when to stop is faulty and or the external power supply is no longer supplying regulated amperage but the amperage supplied to the notebook is oscillating and those power dips are hanging XP.
Of course this is pure speculation. When I bring a laptop in for service on a difficult case such as yours I take it through a systematic series of tests to rule in or rule out components. This is the basic technique to troubleshoot logic systems, which a computer is of course. I have an expensive power supply that I can set the voltage and amperage to and connect it to a laptop to rule in/out an external power supply. I usually take them to a friend who puts them on an oscilloscope with a dummy load and measure the voltage regulator for performance within tolerances.
Another thing to do is repair your XP installation. You have to have your Compaq supplied Windows disc. This is asking a lot as Compaq was famous for not supplying one. The courts ruled in favor of the consumer and they have to give you one on request. You start the installation process from your CD and boot from it by setting the boot order in your system bios setup screen by pressing F10 usually for Compaq/HPs and F2 for Dell and some others. Anyway, the installation starts and you let it proceed normally until it alerts you to the fact that a Windows installation already exists. At this point you will see two options, proceed with new installation or Repair. You choose repair and XP is pretty darn good at healing itself. This resolves a lot of problems and is one thing I always do when a computer is in for service.
A lot of the other things we do are pretty esoteric. So, if the power supply is ruled out at being at fault and the battery holds a decent charge and reinstalling XP doesn't resolve the problem you will need to take this in to a decent shop with a good reputation of being thorough, honest and straight talking with you. You may have to ask around to find one or ask your chamber of commerce.
BTW, error reports in XP are mostly meaningless as a daisy chain of events occur in a failure and the error code usually relates to the last one in the chain not the reason for the event happening.
If you have trouble finding a shop to work on your Compaq you have two choices you can use the shop finder on our home page by entering your zip code for a shop near you or you can consider getting another notebook. I know, sort of giving up on an old friend sometimes. But you'd be surprised what you can get for your money these days. I do a lot of consulting for college bound kids' parents this time of year and I've already gotten one family into a basic machine for $400 and another for $550. If $700-800 is in your range I can recommend many notebooks for you. You can ask it won't cost you anything.
So, you can try the above ideas and by the way a good electronics shop might check out your external power supply for free if you ask to see if the voltage curve is within margin and they can test you battery too to see if its at the end stage of its life cycle.
Feel free to ask any other questions you may have and when you reassemble you laptop remember there shouldn't be any extra screws left over. Ha Ha....
Posted on Jun 25, 2008
  • Glenn Rogers
    Glenn Rogers Jun 25, 2008
    Oh, by the way, if you're feeling generous about this you could change your Helpful rating you made before to a Fixed. That would be nice but isn't required. Its enough you rated at all. You'd be surprised how many people don't even rate at all and we don't get any feedback on our solutions or how well presented they are.
    Just a thought. Look forward to chatting with you again as you move along with this project you have on your hands.
    Problem Solver:
  • 10 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Worldvet ... u're an a55. i fell alseep reading this shiit. and any way, u'r wr0ng. its a duff m3mory that was the problem.
Posted on Sep 23, 2008
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
My hp nc6000 laptop wont boot up i need to reset it to factory setting
When you power on your laptop immediatly after powering on your laptop start pressing F8 key on your laptop keypad, after few seconds Advance boot options menu will appear in front of you in that menu select (repair my computer) option will take you to unother sub menu which will give you an option of load factory image.
Sep 02, 2011 | HEWLETT-PACKARD Hewlett Packard Compaq...
My compaq nc6000 did not start up. The proplem happen when I shut down for 4 days. anyone help!
Leaving a computer switched off for any length of time shouldn't matter. I have had laptops that have not been powered up for 5 years and they power up without a problem once the battery has charged and the BIOS backup cell is replaced.
I would suggest that if you were to press F8 when it is booting up, just at the point when the BIOS menu closes and choose Safe Mode,. Get it to boot from there and it may recover itself. If it doesn't do the same action but choose Recover as an option and follow the prompts.
I hope that helps.
Nov 28, 2010 | Compaq NC6000 C Notebook
I have a Compaq nc6000 that would not boot up. I
Sounds like your display panel is bad or it's another symptom of a mother board flex problem at the Maxim chip
May 22, 2010 | HP Compaq nc6000 Notebook
Hp nc6000 wont bootup
hi thanks for using fixya!
On this kind of error, the only option you could do is to format your system, but if you are not so familiar in formatting your laptop, I suggest that you bring laptop to service tech, to easily perform error checking and reformatting. This error might be virus or software problems.
Thanks! hope this will enlighten you. please rate me! good luck!
Mar 18, 2009 | HP Compaq nc6000 Notebook
Cannot reinstall Windows on my Hp Compaq nc6000
I know I just had the same problem today...when getting into the bios...try using a "multi-bay" boot and have the cd booted first then the hd...That's the only way mine worked to "trick" the system to boot from the took a few times of stalling after that but with frustration and regathering with patience, it finally might have problems with the devices not being recognized after it does load unless you have an easy driver set to install from cd...otherwise you might have to manually install them to make them operate correctly. *hint: using the device manager to see any '?s' and reinstall drivers helped me*
Feb 05, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 won't come on
well make sure the battery is fully charged you could have a bad motherboard or no memeory inside it check those first
Nov 08, 2008 | HP Compaq nc6000 Notebook
Hp compact nc 6000 not powering up
Will your Laptop boot up normally using just battery power?
Jul 09, 2008 | HP Compaq nc6000 Notebook
My computer is an Hp Compaq nc6000 PC notebook
My fan was constricted for about 2 hours and my computer froze.After about a day the computer came back on, the fan fan blew during start-up but cut off and doesn't come back on. The computer freezes and the bottom gets very hot. Whats wrong and how can I fix this?
Jun 22, 2008 | HP Compaq nc6000 Notebook
Boot from dvd
your linux isnt set up to boot use widows inviorment
Dec 29, 2007 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
803 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
