Question about JVC Everio GZ-HD7 Camcorder
GZ-HD7 Computer doesn't recognise camera.
Hi, Running Win XP, trying to upload camera hard drive to Sony Movie Studio V8 for editing via ieee connection. Compuer will not recognise camera. If USB is connected recognition is OK through supplied Power Cinema software, but not through sony. Have uninstalled and reinstalled Power Cinema in case there was a glitch but to no avail. I don't actually want to use the supplied software at all, rather use the Sony. Any help would be very much appreciated.
  • 5 more comments
  • attila0051 Jun 25, 2008
    Followed instructions OK. I have OHCI Compliant IEEE 1394 Host Controller. When opened it states that "This device is working properly". OK what do I do next please?
    Hi, I know there are other software programes out there, but I specifically want to use the purchased copy I have of Sony Movie Studio V.8 which is a very good package. The JVC package is barely enough to view with. In any case I can't understand why the computer doesn't recognise the IEEE conection?
    Sorry Eske, frustration has set in. I don't have any imaging devices listed. Looked in audio and USB - no listing of the camera. Have checked cable (replaced with another) used different Ieee port. Computer makes audio sound when I connect or disconnect Ieee, but doesn't show as "device connected" or display in "my computer".
    Tried that, please see response to Eske.
    Worldvet has posted something but I haven't got it. Could you plese post again. Re compatibility with Win XP - if the camera is not compatible with Win XP why does it recognise the camera through the USB connection?
    Hi Worldvet, That makes a great deal of sense. I had a problem with the TOD extension as well because Sony wouldn't recognise it even though I had downloaded the camera's HD into JVC's software and tried to load that into Sony. Thank you very much for your advice I will download Media Coder and hopefully continue without any more hassels.
    Regards Attila
    Thanks for that. My operating system is Win XP so I don't think the Vista platform info would be the same.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Vista has built in tools for importing video from Firewire or USB. Premium and Windows Movie Maker have internal support for both DV or HDV formats. Vista Home Basic Movie Maker should have DV format support.
The problem seems to be at the DirectShow level or a compatibility issue with particular IEEE-1394 cards so be sure your card is compatible and you have all updates installed.
Here's are some other areas to look at:
- It is very possible that some other software on your system has hijacked the device driver used for DV. Common culprits include some from Nero and Roxio.
Windows communicates with DV devices using two different drivers. One is for control (play, stop etc) and can be used by multiple programs at the same time. i.e., you can have Vegas and WMM controlling the same camcorder.
For the transfer of the DV data that has the audio and video, only one program can access a given camcorder at the same time.
- For current video capture devices, two basic driver standards exist: Microsoft Video for Windows (VFW) drivers and Windows Driver Model (WDM) drivers - be sure to have these updated and installed.
- You may want to take a look a the current update for your software.
(Premiere Elements is now up to 3.0.2)
- Try to capture with different software like WinDV:
- Does the camera show up in 'My Computer'? Are there any yellow marks for your 1394A adapter? Does the computer acknowledge with a 'ding' when the camera is connected?
- Vista has a DV codec for playback or for transferring- be sure you have the latest. As you are probably aware, DV from a camera to your hard drive is a data transfer, not really a capture as no changes are made to the file. The camera should show up as just another external device, similar to a external drive.
Even though it's highly unlikely to have anything to do with the codec, but it wouldn't hurt to update it. A codec really isn't required for transfer. If you do end up with an AVI file and it is also just black when played in Windows Media Player, it means the video IS black (i.e., missing at the time of capture). A codec problem would cause an error message to be displayed.
For More details Click this link
http://www.thedvshow.com/faq-pro/index.php?action=article&cat_id=002&id=624
Thanks
Good Luck
"Don't Forget to rate the Solution"
Posted on Jun 25, 2008
    Guru:
  • 859 Answers
If I remember correct you do have to use USB unless you connect to a MAC, yeah I know its dumb, USB 2.0 is just as fast anyway.
The default file format JVC saves your shots with is TOD as I recall. This is just JVC's version of MPEG2. You can copy the files to a working folder under my documents, my videos and then rename the file extension to .mpg At that point you should be able to call up the file in your preferred software.
If it plays back really slow your camera is recording in too high a bit rate and you will need to use a program called Media Coder to convert it to a lower bit rate (bit rate in video files means sampling rate) frame rates for US are NTSC 23.97 and EU is PAL 29.00
You can get Media Coder for free at MediaCoder.com. If you get the settings out of sorts and the file conversion fails you can reset the defaults for this program from its drop down list in the File Menu.
That should do it so you can work in your preferred program either way. You just need a good working media conversion program. Thanks to the good folks at Media Coder (and I use this program all the time) the program is still Open Source freeware as it started out as a project at sourceforge.net
Regards,
Worldvet
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Jun 25, 2008
    Just to clarify the default file format for JVC digital is *.tod as a file extension. You just rename that file extension to a .mpg and open it in your Sony software.
    Regards,
    Worldvet
  • Glenn Rogers
    Thank you for the rating and if you have any questions about editing and working with your shots just ask and I or another will be glad to help with with some of the tricky parts.
    But, do give the Media Coder program a download and start working with it to get a feel. You may have to convert some of your completed projects to a lower bit rate to get them onto a dvd after you've edited the compilation.
    Once again, thank you for rating.
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 26, 2008
    Vista seems to have a surprise for everyone who uses it. I'd check the JVC camera support page before I went and used Vista just yet.
    Microsoft told people who had installed Vista SP1, to roll that back as it came out broken too. If you can in anyway do it, stick with XP for now, its not going away despite rumors.
  • 2,071 Answers
Your camera system program is incompatible for windows xp that why can't recognize ..,try to checked this out there compatibilty and try find software to make them compatible..
  • 790 Answers
Hello attila0051 !!!
Try connecting to the different slot and try the same old thing what my mate ekse said !!!
Regards
Smilemaker
  • JVC Master
  • 13,433 Answers
Hello, you may have to use the jvc software or you can also try useing the windows movie maker found in
either
start -> programs -> windows movie maker
or
start -> programs -> Accessories -> windows movie maker
if you try useing the windows movie maker you simply need to press on
  • 2 more comments
  • Ekse Jun 25, 2008
    Also have a look around device manager to see if your camera is detected by windows.
    Right click my computer and select manage
    Then select device manager from the left side and look around
    Your camera is most likely in imageing devices
    or in some rare cases if your camera is set in the wrong mode
    you may be able to find it under usb or sound..
    If your camera is not listed anywhere in device manager, its most likely not connected properly or is set in the wrong mode.
  • Ekse Jun 25, 2008
    You rejected my solution too fast! Did you even get a chance to read the rest I just posted.
  • Ekse Jun 25, 2008
    I'l have to go thought the user manual for your product, Il get back to you in a moment.
  • Ekse Jun 25, 2008
    User manual is at
    http://books.jvcservice.com/Download/160...
    The manual suggest to use USB.
    Information on pc connection page 53 -> to page 67.
    Genius:
  • 2,035 Answers
Start > setting > Control panel > System (Switch to classic view if under Category View) > Hardware > Device Manager
Your can found a detail hardware profile list, If your IEEE1394 device had correctly install on your PC system and recognize by Windows XP then you will found a IEEE1394 bus host controller and at least one item of IEEE1394 device (My Sony VIAO is : Texas Instruments OHCI Compliant IEEE 1394 Host Controller )from the list. Please confirm the device status window shown : ( This device is working properly ) or not.
The jvc player is supplied with company software and i think it is not compactiable with sony software as software each company model and make differ in the different software.....................
I have sony trv33 and windows 7 using firewire 1394 port and cable computer does not recognise camcorder when turned on
Your camera will not be recognized when you connect it via firewire. To transfer the video from your camera to your computer you will need a video editing program that is able to capture video from camcorders connected via firewire.
You can try Windows Movie Maker for Windows 7. Alternatively your can search through the internet to find a more advanced video editing software.
Regards,
nicolasiac
Feb 03, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
Everio movie editing
First check sound settings on control panel, ensure volume is not at minimum and computer audio is not muted. Test playing a CD.
this is usually due to Media Player or whatever player you use on your pc, not having the right codecs to decompress sound from camera file.
Usually you sort it out upgrading media player, you can download update from links below.
  1. Windows Media Player 10
  2. Cumulative update for Windows Media Player 11 in Windows Vista
Sep 23, 2008 | Video Cameras
Hi, I have a JVC GZ-HD3U model and I want to tranfer the videos that I recorded to my Macintosh. Trying via Imovie 9 and Quicktime 764 they cannot recognized the video fils
its because its a TOD file and i movie dosent know what it is
i had the same problem and i had to use a program called sony vegas Pro 8 it recognised the video and audio thats the only way ive gotten to files to work
Oct 13, 2009 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
Everio gz-hd7 full hd manual white balance problem
try this
function-WB-MWB-then hold joystick untill it gose back to menu
Sep 16, 2009 | JVC GZ-HD7 HDD HD Camcorder - 60 GB Hard...
JVC Everio Camcorder-cannot make movie file
I use Sony Vegas 8 Movie Studio...a great piece of software...and use the Storm codec pack to view .mod files that the JVC puts out:
http://www.softpedia.com/progDownload/Storm-Codec-Download-20053.html
scroll down to download mirror for STORM Codecs, not AVS.
Good luck.
May 14, 2009 | JVC Everio GZ-MG21 Camcorder
My camera is not reconnized by the computer!
If you are using a Mac, you should also use the firewire cable (not a USB).  Using the Mac program that comes pre-installed on the mac, iMovie, you can then import the movie and save it using imovie. Then you can also, edit and clip and merge and add all kind of special effects, titles and more.
Hope this helps. Call me if you have more questions: 985-419-9937
Apr 23, 2009 | JVC Everio GZ-HD7 Camcorder
Software for GZ HD7 won't install
ew i think you have to un install your vista, use winxp pro sp2, all the budled cyberlink bd software are supported
Oct 27, 2008 | JVC Everio GZ-HD7 Camcorder
Movie Camera and Movie Maker
Hi Am Gayra, Try using the Power Producer which came with the camera
Mar 26, 2008 | JVC Everio GZ-HD7 Camcorder
JVC Everio GZ-HD7 Camcorder Logo
244 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
