Question about Panasonic KX-T7730 Corded Phone
Switch on music
Hi how would you switch on the music (which has already been connected to the main PABX) at each individual handset?
  • jon_than21
    jon_than21 May 11, 2010
    just press 1, that if you already activated the external music source thru system programming.
  • 30 Answers
At any pt-phone, press 1.
Posted on Jul 25, 2008
Panasonic pabx
The problem is with the pabx switch not the phone. Wire the station to another port.
Mar 14, 2014 | Panasonic Computers & Internet
Phone disconection
cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU butTton on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced CERTIFIED UNIDEN EXPERT
Jan 21, 2011 | Uniden Cordless Phone
At&t 3358 base speaker is not working
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with phones.
Jan 20, 2011 | AT&T 5840 5.8GHz...
Tidak bisa membuka Applikasi Dan Games setiap kali dibuka Operasi Gagal
Jan 20, 2011 | Sony Ericsson K810i Blue Smartphone
Hi, I have a Siemens ( 4000 series) land line phone with an extra hand set. What steps do I need to take to have the second headset sync(?) to the same base so that both headsets are usable? I can not...
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones
Jan 17, 2011 | Lands Phones
I would like connect kx-t7730 to tda100 .can I connect it ?
Yes. However, it will only work if you have the 8-port hybrid card(TDA0170) installed. Besides costing a lot more money(the card, not the phone) the phone uses 4x the power of a 76xx or DT series phone and you only get 12 lousy working buttons.
Carl
Nov 30, 2010 | Panasonic KX-T7730 Corded Phone
HELLO EVRY BODY, We have a cordless phone gigaset 4015 with gigaset confort handset 4000 the only problem is when we receive a call , we can hear only the first ring and the handset still blinking...
First of all you have to change the Dialing mode, DTMF or Pulse, according PABX type, ask to technicians!
Second step is to set up the Flash Time from 80 to 800 ms, again in dependency of your PABX Operating Instructions. Cheers and good Luck.
Oct 09, 2017 | Siemens Gigaset 4015 Cordless Phone
Unable to load file from PC
1.) Select Memory Card in the handset : Main Menu > Multimedia > Music Library > Menu Key > Switch Storage Device > Memory Card.
2.) Connect the Handset with PC using Data Cable.
3.) You will get a prompt in the handset : Use as Mass Storage : Yes
4.) Go to My Computer, you will find a removable drive.
5.) Copy and Paste the Songs and Pictures in Removable Drive.
6.) Make sure that the keypad of the handset should not be closed during the entire process.
May 19, 2009 | Motorola Cell Phones
On hold device
Start by looking at the system. It's pretty tough to miss the two jacks labeled MUSIC and PA.
They take a 1/8" (3.5mm) mono jack, so you can come out of your MOH device with an RCA to 1/8" or 1/8" to 1/8" cord. Your local Rat Shack should have the cables.
Carl
Feb 26, 2009 | TalkSwitch CT.TS001.124001.US...
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
