Akai AP005 Turntable Belt - Audio Players & Recorders
  • Mirage 1 Jun 26, 2008
    Have located one here The belt is a BLT380, thanks for your reply though.
    Paul
  • 1,512 Answers
Hi Mirage 1
Can you measure the diameter of the platter pully. This is the best way to get the right belt for your T/T. If you get the diameter, you can call to most any Specialist HiFi shop, and they will have a belt for you. You can also order on online. Let me know what diameter you need and I will help you find a source.
robotek
Posted on Jun 25, 2008
  • Graeme Ross
    Graeme Ross Jun 26, 2008
    Ok Paul, no worries. Glad you got it sorted. The thanks for trying vote is generally used in "thanks,but I dont need your kind of help" situations, well it is to us experts at least. It has depreciated my hard earned overall ranking in FixYa,so was hoping that you could upgrade me...:) Cheers:)
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
Where do I get set of hinges for dust cover of AKAI AP-X1 turntable
Check on ebay for that tt and maybe someone has parts listed. Or try the manufacturer but if a unit is more than ten years old parts are usually no longer available.
Nov 22, 2015 | Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
What size belt do I need to get for an Akai APB1
Go to vintage electronics.com and put in model #. Very quick turnaround.
Jan 12, 2010 | Audio Players & Recorders
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
Rubber band for Akai semi automatic turntable APX1 needs replacing. Where can I buy one in NZ?
Are you sure you have an Akai APX1? I've never known Akai to make turntables. I think you mean AIWA - yes, there is a MAJOR difference.
For the Aiwa APX1 model, you can purchase the belt HERE.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 31, 2009 | Audio Players & Recorders
Have akai ap-b110 turntable needs belt. Can you tell me the length/specs
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Jul 08, 2009 | Audio Players & Recorders
Akai ap500 turntable rubber belt is off and dont know how to put it back
can you look under the turntable flywheel and see the flat edge around the flywheel ? that is where the belt will go around then around the motor shaft ( you may need to take the flywheel off by taking the C clip off of the center of the flywheel)
Apr 30, 2009 | Audio Players & Recorders
How to remove platter from AKAI AP-B110 turntable
On my Akai turntable, I have to remove the fiberboard bottom cover (nine screws, nothing tricky) then there's a central brass air bearing with a small set-screw in the side. Loosen the screw, and the central turntable axle lifts right out of the bearing.
This is a belt-drive Akai - your mileage may vary.
Mar 24, 2009 | Audio Players & Recorders
153 people viewed this question
 Grubhead
Grubhead
