Question about Toshiba Satellite P105-S6104 Notebook
Toshiba I cracked my laptop screen. how much does it cost to replace it.
  • 405 Answers
It could be quite expensive at a repair center maybe as high as 400-500 dollars, however if you have some expirence working on computers you can purchase a used screen from ebay or other sources for around 100 and put it in yourself. Follow this link for an overview of the procedure:
http://www.tomsguide.com/us/how-to-replace-a-broken-laptop-or-notebook-display,review-649.html
Good Luck
Posted on Jun 27, 2008
My screen on my toshiba laptop P775 comes on but looks broken
If you mean broken as in it has a crack, it has liquid effect leak or dark then yes you have a broken lcd
Replacing is not a difficult as it seems, mainly by removing a few screws around the frame hidding under the rubber pads, then sometime you also need to remove the keyboard/power control panel, then its jsut a case of removing the broken lcd and buying a replacement panel and fitting it.
heres me taking a panel out on another laptop but gives you the idea.
If your in London, then I can do the repair for, cost of parts + 20pounds + return delivery costs.
Feb 03, 2013 | Toshiba Satellite P775S7236 Notebook
CRACKED SCREEN
Go to www.ebay.com Type make and model of laptop, refine search to screen and go through the price listings.
Jul 21, 2012 | Toshiba Satellite 4010CDS Notebook
Toshiba AA67-00136B
It depends on the model---older rear projection sets maybe---newer LCD or Plasma---NO----cracked or damaged screen on those is the end as part costs are more than set was new.
Mar 21, 2012 | Toshiba Televison & Video
Cracked screen. replacement cost?
Around here, about $110 for a "pre-owned" compatible LCD screen,
from the local Computer Store that has various screens on "consignment",
or about $220 for a brand-new compatible LCD screen.
Add $65 for installation.
Jun 06, 2011 | Toshiba Satellite A505DS6008 TruBrite...
Crack damage LCD toshiba note 10in
Did you crack the screen, causing problems with the display? If you do not want to get a new laptop, you can contact Toshiba if you are still on warranty to get a free replacement screen, or to purchase a new display.
Jun 01, 2011 | Computers & Internet
I have a 52" Toshiba
in general cracked lcd panels cost more than the tv is worth.. depending on model panel replacment run 1500 to 2000.. and physical damage is not a warrenty item. do you have a toshiba or a rca the decription says you have rca r52wm24 which is not a lcd. that is a tube tv. and if it is cracked that definatly can be fix or replaced cost effective.
Oct 27, 2010 | RCA R52WM24 52" HDTV Projection Television
Were in India (gurgaon)can i get my toshiba A Satellite Series screen repaired and what is the cost? The screen has cracked accidentally !
just fyi before you make any decision on laptop screen repairs.. we have found that the screen costs just as much a new laptop (that is if you have a cracked or broken screen). better off buying a new laptop.
this is only valid if the laptop is not under warranty. If it is under warranty best to check the Toshiba website for accredited repairers in your region/location.
good luck hope this helps'
Oct 08, 2010 | Toshiba Computers & Internet
My Toshiba 50" Projection TV Model #50A50 screen has a crack in it. How do I replace it? or fix it?
There are two screens involved here, the protective screen (outer) and fresnel screen (inner). You do not indicate which is cracked. I have listed the part numbers and costs from tritrinincsinc.com below:
fresnel screen - part number 23430784 Cost: $133.01
protective screen - part number PS5001 Cost: $162.73 (no longer available)
You can check with local service centers for the protective screen as some may have one around in stock but it is no longer availabel from Toshiba.
Dan
Oct 08, 2008 | Televison & Video
Toshiba laptop cracked screen
you can use external monitor, but best option is to replace the cracked screen. Take a tour of toshiba service centre.
Thanks and Good Luck
Iqbal
Jun 26, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba LCD Screen Replacement
The problem will be cost. In most cases to replace the screen will pass the cost of replacing the television.
Nov 25, 2007 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Toshiba Satellite P105-S6104 Notebook Logo
385 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
