Question about Acer Aspire 3680 Laptop
Laptop problem i have this laptop acer aspire,i accidentally disable the adapter & monitor in the display settings/properties,my monitor now is not working i cannot see anything on the screen, how can i get it back and working again,please help me thanks
    Genius:
  • 2,785 Answers
Can you see the bios screen then follow the following
when you laptop is booting press F 8 then select boot in safe mode then from device driver you can enable the display adapter.
post your findings
Posted on Jun 25, 2008
Solution for aspire 4745g when installing for ati driver it turn black?
An ATI adapter is a type of video adapter that is designed to be used on computers running Windows. If the adapter is disabled, you will not be able to connect any external monitors, video projectors or other similar devices to it, as your operating system won't be able to recognize it. Of the different ways you can enable this type of display adapter, one is through the "Display" manager in the Control Panel.
Click "Start." Click "Control Panel." Click "Display." Click "Change Display Settings." Click "Advanced Settings." Click the "Adapter" tab. Select the ATI adapter from the list on screen. Click "Properties." Click the "Driver" tab. Click "Enable" to enable the ATI adapter through the "Display" manager.
Or the driver you are installing is not compatible with your operating system or your computers hardware
Hope it helps
Jan 23, 2013 | Acer Aspire 5602WLMI Notebook
How to connect external monitor to aspire 3000
plug in the new monitor to the notebook, then right click background and then click properties. Then go to the settings tab, at the bottom of that click advanced. Next Click monitor. There you should see the external monitor for you can set the display to this one.
Oct 25, 2011 | Acer Aspire 3000 Notebook
My aspire screen is upside down and the picutures are also upside down. How can I fix it?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 02, 2011 | Computers & Internet
Acer 5730 - Display blinks constantly
Please disable the User Account Control feature.
You can disable the UAC from User Accounts in Control Panel. Also, reinstlal the Video Driver to resolve the issue
Jun 30, 2010 | Acer Aspire 5610-4648 Notebook
How do I change from the computer monitor to an external monitor with the acer aspire one 150 netbook computer
try FN + F8 to toggle the display. if it does not work, go to the vide card display properties, select the second monitor and set it to your preferred option.
Oct 23, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Both screens wont work
No mention of how much ram installed ???
Are you using ACER GRIDVISTA
This program handles the multi screen out put
or
Standard Screen Properties,,,,,,,
Try this
DESKTOP>Right click properties
DISPLAY PROPERTIES>Settings
With both screens connected.
There should be two windows displayed ,
a highlighted white one and a grey one
Click IDENTIFY.
ONE SCREEN-
Should display a number 1 on the screen it has attached.
TWO SCREEN
Should display a number 2 on the external screen.
Once you get IDENTIFY to work then set resolution sizes of both individual screen.Apply and ok to save settings
If using GRIDVISTA then set the setting for the output functions and save theme as a theme BOTH or LAPTOP AND EXTERNAL MONITOR and its accessible from the desktop right click.
Good luck I have a couple of these I use for my Media Centre wirelessly networked thru the house.Great machines.
Jan 11, 2009 | Acer Aspire 3680 Laptop
Still not working
try hooking up an external display and restore the settings , if that don't work you will need the operating disk to reinstall system files and you won't lose any data and the display settings will be restored
Jun 26, 2008 | Acer Aspire 3680 Laptop
Monitor not working
try going to safe mode,restart pc then press f8 for advance boot menu,go to safe mode,choose administrator,reenable display adapter again..eiether thru device manager or display properties
Jun 25, 2008 | Acer Aspire 3680 Laptop
Laptop powers up but does not display desktop
How to enable / disable windows active desktop. Open Display Properties. Click the Web tab in the Display Properties window.
DirectX Help Get the computer into Safe Mode. In Safe mode, click Start / Settings / Control Panel and double-click on the display icon.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
