Question about GE Ovens
GE JCB909 Range - Blank display
Brand new stove. Power is going to outlet. Blank display on range. Turned on a burner, then display appears and clock can be set but everything disappears as soon as burner is turned off. Burner does not appear to be heating either. Tried blank display reset with "bake and broil" buttons as well and 9 and 0 but nothing happens.
It's so frustrating!
  • Anonymous Mar 14, 2014
    we mash the bake button, and then start, and nothing happens
The problem was not with the stove, it was with the electrical box - it was wired incorrectly.
Even though power was getting through it was not the way it should be. Electrician made repairs and stove appears to be functioning correctly.
Posted on Jun 26, 2008
    President:
  • 1,462 Answers
Suspect wrongly wired from new
Posted on Jun 25, 2008
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
I have just moved into a new house with but i can't get the westinghouse PHL768U oven to work. I need help in setting controls like time etc. I havent got any manual. Please help
Chances are, its been turned off and you have had the power turned back on... I found this out as well, that you need to 'acknowledge' the stove... press the centre button by the clock display, and this should beep.. you should then be able to have the elements turn on, and if you want, set the clock.. See the display, and there will be a small red light, that bounces round from corner to corner when you press the Mode button. ie, if the red light is next to Clock, then you can adjust the clock time etc etc.. hope this helps.. otherwise, we also had to find the Range Power switch going to the stovetop...
Jan 28, 2011 | Ovens
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
What could be the problem if F1 code and beeping in GE wall oven/
F1=Touch control pad and or Clock defective.
Jan 11, 2011 | Ovens
Displaying F1 error
Apr 04, 2010 | GE JGRP17 Gas Single Oven
F1 error code, beeping
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    GE glass top and oven are not heating?
    I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
    Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
    Frigidaire Oven - lights are on but no heat from oven or burners
    You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
    Jun 26, 2009 | Frigidaire Ovens
    "F1" error code on Magic Chef gas range Model 3488XRA
    the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
    Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
    Ovens Logo
    309 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
