F-40 White screen
You sure the f-40 has to be off so windows can go into recovery mode? Thanks I appreciate the help!!!!
  • 8,596 Answers
Make sure you reset the player first
Yes, IF the method works for your player, the player must be turned off before replugging
The support website for this product is non-existent for a Toshiba F40 - it has a "T401," but it still has no FAQ or user's manual; I found a firmware update when i entered firmware f40, but i cannot verify if it was the correct model # firmware upgrade
Since the support is so sucky, I would consider calling Toshiba for a solution. It's an older model, so they may not even support it anymore (in Mp3 time, 3 years is old)
Posted on Jun 25, 2008
Where can I get the touch pad driver for a SoundLogic XT Android 2.3 tablet? I would appreciate the help. Thanks
you have to do is put it in recovery mode (pressing a combination of buttons) Then reload the os with either sd or flash im not sure until I get the os what will work. If we can put the working one into recovery mode we might be able to copy it for use on other machines.
Oct 27, 2014 | Tablets & eReaders
Toshiba stuck on start-up screen.
The windows files have been corrupted, I was hoping you might get into safe mode to try a system restore but your system will not allow it. If you can find your recovery disc a clean install is the best way to go. Try www.toshiba.com contact customer support about a replacement recovery disc.
Jul 21, 2012 | Toshiba Satellite A205-S6808 Notebook
Blue screen of death
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
Jan 26, 2009 | Dell Inspiron 1501 Notebook
White screen zd7000
Just click on the download link and follow the on screen directions Altough i think you need to replace the lcd screen. It might be cheaper to buy a new notebook
Here is the driver site
Oct 06, 2008 | Acer Aspire 5630 Notebook
Laptop will not boot up OS
Try running the Recovery Concole using your Windows installaiton CD (assuming you're running Windows XP).
Insert the CD and as the computer boots, look for the prompt that asks you to press any key to boot from the CD. Press any key on the keyboard and you will be taken to the Windows Setup screen.
Press 'r' to enter repair mode.
You should see this:
The Recovery Console provides system repair and recovery functionality.
Type EXIT to exit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log on to
(To cancel, press ENTER)?
Hit 1 and press Enter.
You will then be at a C:\ prompt. Type chkdsk -r and hit enter.
This will scan your harddrive for errors and fix any errors you may have.
Take out the CD and reboot the computer, see if it works now.
Here is a link to more detailed informaiton about using the Recovery Console to help resolve you boot issues:
http://support.microsoft.com/kb/314058
Sep 04, 2008 | Sony VAIO VGN-FS980 Notebook
White screen zd7000
It may be a power problem. The battery may not be charging.
Aug 16, 2008 | Averatec 6100 Notebook
Boot up
Fatal registry error, reinstall a fresh copy of windows.
Jun 06, 2008 | Packard Bell Easy One Silver 2101 Notebook
White Screen on Toshiba Gigabeat F40
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 31, 2008 | Audio Players & Recorders
My toshiba satellite a105-s171 will not boot up. it acts like it is starting but after the windows xp screen a blue screen flashes with white lettering but does not stay long enough to read and then the...
You need to do a recovery using the recovery console. There is an option during startup, if you are running XP or later, to press F11 for emergency recovery.
Press F11 and choose the option to recover and backup.
This will backup all files and programs currently installed on your computer.
After the recovery process finishes, you will have to go through the process of setting up your computer, like you did when you first bought it.
After you are all setup again, it is a good idea to create recovery disks under the 'Start' menu, 'Recovery' option.
Apr 12, 2008 | Computers & Internet
White screen only
Apr 15, 2007 | SanDisk Sansa e260 MP3 Player
46 people viewed this question
 Grubhead
Grubhead
