Question about Indesit Washing Machines
Indesit WI 62, i believe it is error code 5 as washer won't drain or spin & when reset clicks round the contol dial with five led light flashes intermittently. So, how do I repair the pressure switch & where are the pump & filter located so I can properly check for blockages?
    Genius:
  • 1,847 Answers
It seem issue with the water senser.
Posted on Jun 25, 2008
  • Legin Varghese
    Legin Varghese Jun 25, 2008
    open the back of the unit you will see a small tube that goes to the level sensor, unpluge the tube and blow pressured air from ur mounth.... the porcess is **** and blow. this should fix....else the level sensor need replacement.
My machine starts to fill and then stops. It flashes 7 times. What is this error?
What is the Brand and model of your washer ?
Is it Indent ?
Many basic UK Indesit washing machines fitted with a rotary dial indicate error codes by clicking the dial continuously round and flashing the door lock light a set number of times.
If the door light (LED) flashes 7 times it means, "Heater relay stuck - check connections on heater and module (PCB)".
In my experience, this fault code usually required a replacement PCB and EEProm. A connection fault on the heater usually results in the entire washing machine going dead. Nothing will work, but the LEDs light up. This symptom can also be caused by an open circuit motor or other faults.
It's always possible for a connection fault to cause error codes but the heater relay is embedded in the PCB and if it develops a fault the whole board needs replacing. I don't recommend replacing the PCB as a DIY repair. It is an expensive part and it will not be guaranteed unless fitted by an engineer. New PCBs do not come with the micro-chip EEPROM which would also need fitting. Replacing the PCB and EEPROM yourself is risky. If the fault is not cured you cannot send the parts back.
If you have an engineer to replace the PCB and EEPROM I would imagine the cost is likely to easily be over £100. If your washing machine has a 5 year parts guarantee Indesit would supply the PCB free of charge but only if their own engineer fits it at a cost of about £90.
If you are really keen to fix this yourself and want to try another PCB there is a company that might be able to help and are happy to deal with the public called Quality Electronic Repairs (see link below)
Mar 07, 2016 | Washing Machines
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
My washing machine has just decided to stop before spinning and the dial continues to click round and round and round... Its still full of water...... What do i do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Indesit Washing Machines
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Indesit W123 - 8 Flashes Error Code
thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Oct 26, 2007 | Indesit W 123 Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
585 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
