Question about Dishwashers
Ariston ls2020 dishwasher dishwasher will not fill with water
Works in all other cycles but no water. i have tested the water to the house and the dishwasher does have water going to it.
    Problem Solver:
  • 5 Answers
Anti flood device has been activated on inlet valve so appliance will not accept water
Posted on Jun 25, 2008
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
Hello I have an Ariston advantage AF300 dish washer. And it has stopped working properly. The problem seems to be that no water is being sprayed around inside. The machine works its way through the...
Hi
You either have a food or glass particle lodged in the wash motor impeller not letting it turn or more likely the wash motor capacitor needs replacement.
I suggest getting a repairer as the Aristons are tricky to repair.
Ash
Sep 03, 2011 | Ariston Technologies Dishwashers
My dishwasher is running but not filling? Water is on & connected but can't work out why it won't fill. Any solutions? Thanks
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 13, 2011 | Ariston Technologies L63SNA Stainless...
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Does not fill or drain.
Test the timer control board and the impeller pump.
pump is tested by energizing. Board is tested using a multimeter.
Observe strictly safety rules.
May 21, 2009 | Kenmore Dishwashers
My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Apr 08, 2009 | Dishwashers
Does not fill with water
fixed problem by throwing machine out into back yard and buying new one. seems to have worked up to now
Dec 03, 2008 | Ariston Technologies L63 Free-Standing...
Ariston dishwasher
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Mar 01, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
306 people viewed this question
Top Dishwashers Experts
