Question about Dometic Rooftop RV Air Conditioner
Back to the high cool and high fan not working .
Do you think it could be the fan capasitor? or is it even worth trying.
    Master:
  • 848 Answers
Mostly it will be fan
Posted on Jun 25, 2008
My good man furnace model gmh80903bnca will not get to temp fan shuts off and burners keep burning then kicks off on high limit then starts process over but never gets to temp set at 655
If you have a switch that can manually turn on the fan, try it to verify the fan works. This is what I think is happening. The normal operation should be thermostat calls for heat, inducer fan comes on, pressure switch closes, igniter glows, main burner ignites and then in 30 or so seconds the fan comes on and stays on until the thermostat is satisfied. Once the thermostat is satisfied the burner shuts off and the fan runs for approx 120 seconds then shuts off. I think the control board that automatically turns your fan on is faulty. On most modern furnaces if the auto fan control fails and the furnace gets to hot and limits, when the limit opens and shuts off the burner it also energizes the fan motor to cool the heat exchanger.
Jan 13, 2018 | Heating & Cooling
if even after changing the capacitor the fan does not run on its own , so it indicates the weak fan motor .but before that check whether the bearings are chocked up ,sometimes even choked bearings cause this type of problem.
for any further queries feel free to ask.
thanks
Sep 18, 2008 | Dometic Rooftop RV Air Conditioner
Air condition fan not working and inside the vent is not cooling
fan moter may be bad if it will not run it will cause the compressor to overheat and it will not cool also check the capasitor
Aug 12, 2010 | Goodman CKL42AR42 Air Conditioner
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Jul 29, 2010 | Heating & Cooling
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
Air conditioner comes on but nothing moves
Take the front cover off..
Inside you will see a barell fan..
Turn the unit on and give the fan a good spin by hand.. If it comes back on - the fan was stuck.. And is a sign of the fan motor on is way out - or maybe a bad capasitor.. If the fan does not come back on - the fan motor could be bad or maybe the capasitor..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 04, 2009 | GE AJCH10ACB Built-In Room Air Cool Unit
Sometimes the TV comes on and works fine with no problems for weeks, other times it will not come on at all, not even a click when pressing the on/off button. Strange but seems to work ok in hot humid...
Check your all capasitors of pwd supply any capasitor is lickege or short or not work poperly if you cann't find any problem replace your all capasitors of pwd supply
Mar 08, 2009 | Televison & Video
Mar 08, 2009 | Zenith 12vDC 800mA 20W AC Adaptor A41208...
Dometic Rooftop RV Air Conditioner Logo
32 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
