Question about Microsoft Windows XP Home Edition
Usb device hanging problem
I have windows Xp installed with service pack 2 in it.
Whenever i try using USB port machine hangs and thn I have to restart it. Other than that, If i insert webcam or flash drive while booting it runs ok...but the moment i eject it and / or re insert any usb device it hangs..
please suggest
    Genius:
  • 2,785 Answers
Plz check for viruses
Posted on Jun 25, 2008
I tried to reformat my computer using windows xp prof service pack 2,completed the set up up to the installation of devices such as keyboard and mouse. but as installing networks reached about 35 percent,...
I sugest you get a new Windows XP SP2/SP3 CD/DVD for the instalation. It may be that the installation media you are using has problems. Another option would be to retry the installation with another CD/DVD Drive and see if the installation will complete. You can also use WinToFlash utility(www.wintoflash.sourceforge.net) to create a bootable USB drive with WinXP and install from it. Hope this solution helps.
Jan 14, 2011 | Microsoft Windows XP Professional SP2
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
My old keyboard exchanged for the new one, does not work
You should not need any additional hardware - but you may have to install a driver (software).
If you just bought the keyboard it should have come with an installeation disc. If you don't have that you can go to the following Logitech website and peform the auto scan function (your new keyboard should be attached via USB cable.
This scan will detect the keyboard and tell you if you need any additional drivers installed.
Apr 03, 2010 | Logitech Wireless Access Duo Optical...
HP KQ246AA USB Web Cam causes hang on boot
1) I guess the problem is that u need to install the patch and try, u can download the patch from below link and follow the directions
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=228&softwareitem=da-66961-1&lc=en&dlc=en&cc=uk&lang=en&product=3737180
else
Unistall the drivers and reinstall the drivers again it will work and Update windows xp sp2 to service pack 3
Dec 29, 2009 | HP KQ246AA Deluxe Webcam
Activate usb port for my computer
you need to install update then windows XP to service pack 2...
The USB drivers are there in service pack 2...
Mar 21, 2009 | E-Machines emachines (emachinees) CD-ROM...
USB HUB, Receiver & Keyboard
dude
Try to update windows xp service pack, i guess usb root hub drivers is missing, when you updated windows xp they will get fixed by itself
Dec 18, 2008 | Microsoft Windows XP Professional
Hi-speed USB device plugged into non-hi-speed USB hub
Hi Shiva,
Did you try to boot into your BIOS and check the settings for your USB port? Often you can set the compatibility mode there.
Secondly, try to connect the usb device to different USB ports on your PC, they might not all be connected to the same controller (front or rear for example).
Jules
Aug 24, 2008 | Microsoft Windows XP Professional With...
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
System hang through usb device
If this problem is really occure when you connect the data cable via usb port make sure that your ep instollation is properly or not .If you were installed the os service pact 2 in the system very quickly it may do happend.It certain to check your available memory,processor speed & ram,s performance.Becoz sometimes insufficient memory can cause the symtem hang.if you have installed you data driver properly this may be the reason.
Dec 19, 2007 | Computers & Internet
Microsoft Windows XP Home Edition Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
