Question about Celestron NexStar 11 GPS (660 x 279mm) Telescope
Focusing Issue Last night, I used my Celestron 11" NexStar11GPS for observing and astrophotography, and it worked like a charm. Tonight, with the same equipment, I am unable to focus the telescope at all. I turned both the coarse and fine focus knobs counterclockwise as far as they will go, but every object is still out of focus--and once I reach a certain point in turning the focus knobs, the object simply moves in the eyepiece rather than becoming more focused. This problem is present with or without the use of a diagonal. The only thing I did with the telescope between last night and tonight was to mount a Celestron StarPointer (a holographic sight-type finderscope) onto the side of the telescope tube's back end with some 8x32 3/8" screws using pre-drilled screw holes. What happened?
  • coderedd Jun 27, 2008
    Yeah.. I inspected the primary for any visible damage yesterday and found that it was bumping into the tips of the screws. Shorter screws fixed it! Thanks anyway.
  • 44 Answers
The screws should be short enough not to stop the primary's travel, but pull them out and try it again. Good luck! George.
Posted on Jun 27, 2008
Cpc 1100 miracle or fail?i can observe sky objects same size and same quality with my celestron 70 eq and cpc 1100 ? i used different eye pieces but nothing changed.No nebula,no galaxy or better view of...
WRONG-- completely wrong. No way a 70mm scope will show the same as a 11 inch scope. UNLESS you point them to a star. All telescopes show stars as simply a point of light they are TOO far away to see a disk. Objects in the night sky are tiny-- smaller than the tip of your finger held at arm's length. The scope must be pointed DIRECTLY at them or you will not see anything. What you need is a little bit of knowledge about the night sky--
Download this free software:
www.stellarium.org
download this free monthly star chart:
www.skymaps.com
and located an Astronomy club nearby and the members will help you learn the night sky.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Aug 30, 2011 | Optics
Cant see anything
Can you see anything during the day time? Practice focusing during the day time on a distant object using the eyepiece with the largest number written on it.
The moon should be your first target at night.
Mar 20, 2011 | Celestron NexStar 130SLT (31145) (306 x...
Having a clear sky last night i took my new scope out and started to view the night sky, but focusing on a star ! i found that when viewing it at magnification a could clearly see the the area infront of...
Stars are ALWAYS pinpoints of light when the scope is focused no matter how much magnification is applied.
You are NOT focused properly -- when you are you cannot see the secondary mirror or the "spider" bracket that holds the mirror.
You will NEVER see a star as a disk, only as a pinpoint light. If you are seeing what looks like a donut with a dark center you are not focused.
May 07, 2010 | Celestron PowerSeeker 114 EQ Telescope
I have a CPC11GPS telescope that was working the last time I used it, which was 6 months ago. It is in NEW NEW condition. I pulled it out last night, turned it on, allowed the system to align itself using...
The clutch is not engaging in RA. Maybe the gears are not actually meshing together? A loose worm gear?
You can open it up and look and see if anything obvious is loose. Otherwise it's a trip back to Celestron.
Dec 04, 2009 | Celestron Optics
How to set up telescope cant seem to see anything at night
Put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow if you have one.
Go outside during the day and practice focusing on a distant object. The one with the largest number is also the lowest magnification.
Oct 08, 2009 | Celestron Optics
Focus knob on Celestron NexStar 5 does not appear to be working. Knob still moves but does not sharpen the focus.
Does the focuser move in and out when you turn the knob? If it does then go outside during the day timne and practice focusing on a distant object. Use the eyepiece with the biggest number written on it.
This will give you the lowest magnification-- which is easier to focus.
Aug 02, 2009 | Celestron NexStar 114GT (269 x 114mm)...
I have a 21086 and cannot see anything?
Put in the eyepiece with the largest number written on it--- and take it outside during the day and practice focusing onj a distant object. The moon should be your first night time object.
Jul 05, 2009 | Celestron Optics
See nothing but black
Put the lowest magnification eyepiece in the telescope. It's the one with the LARGEST number --- try focusing on a distant light at night or distant object during the daytime.
Dec 28, 2008 | Celestron Optics
Celestron nexstar 11" gps scope
Be sure that the Azimuth Axis is Lock, you migth want to try and move the telescope in the Azimuth to make sure it is it is locked. Be carful not to force it. I have seen on some post where the locking part of the Azimuth somtimes breaks. and the Azimuth Axis will just spin freely Locked down or not.
May 19, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Celestron Nexstar 11 GPS Electrical problem
The Nexstar11GPS group on Yahoo.com.
http://tech.groups.yahoo.com/group/NexStarGPS/files/n11gpselectronics.zip
Nov 06, 2007 | Celestron NexStar 11 Telescope
Celestron NexStar 11 GPS (660 x 279mm) Telescope Logo
133 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
kenneth njonjo
Tony Parsons
Tony Parsons
Are you a Celestron Optic Expert? Answer questions, earn points and help others
