Question about Danby DPAC9030 Air Conditioner
Red flashing light
Dear nanoe,
Did you ever fix your Danby red flashing (full water tank) problem? If so, please let me know what you did.
Cheers!
Had the same problem, thing shutting off after an hour, no water in the tank. I had the external tank attached, was always bone dry. What I didn't know was on the side, there is a slide out tray which acts as the internal tank. The lid to that tank activates a micro-switch which tells the unit that it's full. This tank was dry too, but the switch was getting jostled, casuing it to trip. I've taped down the switch now, and it's fine. I check the tank every few days, just to be safe, but it's never got any water in it. Hope this helps.
Posted on Jul 25, 2009
Red light and beeping on danby air conditioner dpac120068- what does that mean
Hi There,
If you have check and emptied the water bucket, the problem could be the water level sensor. Please contact our customer service department to be connected to a technician who can assess the unit. The office hours are Monday to Thursday 8:30-5pm and Friday 8:30-4pm. The phone number to call is 1-800-263-2629
Thanks and have a great day!
Jul 27, 2012 | Danby Heating & Cooling
Red light on my full size Danby freezer is flashing what does that mean
I am a representative of Danby and would be happy to answer your question.
Not knowing the model number of your freezer, I can tell you that in general the little red light outside the freezer is an indicator light showing that there is electric power coming into the unit. It has nothing to do with the sealed system and the unit will continue to operate normally.
This indicator light is as strong as a Christmas light and there is no need to be fixed or replaced.
If you have any further questions please contact our consumer service department at 1-800-263-2629 and one of our representatives will be happy to assist you.
Feb 08, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
My unit is flashing a red light in the water full indicator. Therefor the air conditioner will not function. Both water tanks are completely empty. It is a portable Danby unit. Model SPAC 8499-3. Any...
You may need to reset the unit, if you did not turn it OFF & unplug it when you drained the tanks
To reset the units electronics, turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in & turn it ON. The electronics should have reset and reverted back to the original factory settings. If so, you can adjust the settings to where you like.
Hope this helped you & thanks for choosing FixYa.
Sep 09, 2011 | Danby Heating & Cooling
I have misplaced my operating instructions for my Danby dehumidifier model DDR 3008 EE. When I plug it in, turn it on, it runs for maybe a minute then the red full water tank lights up and it quits. The...
The model number you listed did not reveal anything. However, the link below is a link to a Danby model, that had a model number closest to yous. Most of the units have the same parts and function. Click n the literature tab and the Owners Manual will come up.
http://www.danby.com/product/DDR30E/12
Hope this helps you. Please let me know.
May 15, 2011 | Danby Dehumidifiers
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
Red light on??
that means the internal tank is full and needs to be emptied. Drain useing a bucket or the hose that came with the system. Open up drain caps and just drain it. Top and bottom caps.
Jul 16, 2009 | Danby DPAC120061 Portable Air Conditioner
Water indicator light always blinks
Internet or email... check the water levelswitch or better yet go straight to the horses mouth! Thank-you-very-much!
Jul 27, 2008 | Danby DAC8003D Air Conditioner
Red light is flashing continuesly
Ok I found a temporary solution. I opened up the unit (yes there are a lot of screws) I checked the float switches and they worked and even unplugging the water level wire connection to the main board did not get rid of the red flashing light. But if you unplugged the connection from the front panel to the main board but leave the infrared remote still plugged in the main lights and control are not on but you can still work the unit by remote. When in this configuration the compressor will come on and the unit will cool. So I think that part of the problem is on the front panel circuit board or maybe somewhere on the main board. But physically the compressor/relay/ switches work. A short term solution until I can get a new board.
Cheers!
Jun 10, 2008 | Danby Portable Air Conditioner
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Aug 24, 2007 | Danby DPAC10031 Air Conditioner
Danby water tank
this part is the indicator to activate the interlock that stop your deshumidifier when water tank is full. It activate a switch on the top right of the placeholder of the tank. when the switch is relaesed it tells you either thank is not there or full and light a red signal. the center of the wheel should be back the pivot. if the pivot is broken, i don't suggest you to forced the switch activated unless you use the direct drain, or you might have water spilled over a full bucket! Martin!
Aug 04, 2006 | Danby DDR451 Dehumidifier
Open Questions:
See all Danby DPAC9030 Air Conditioner Questions
Danby DPAC9030 Air Conditioner Logo
381 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
