Question about Haier hwr10xc6 Air Conditioner
Dehum what does the dehum button mean on my air conditioner. Is it ok to keep the air conditioner on fan when it is spitting out water or should it be on the dehum button?
    Scholar:
  • 104 Answers
Dehum is short for dehumidify. This setting is to remove the humidity from the air without doing any real airconditioning. Also, if the a/c is spitting water out the front, then the a/c is leaning forward too far. The a/c should be at least level or maybe leaning toward the outside a little bit to help facilitate drainage.
Posted on Jun 25, 2008
Spitting water
Fan spraying condensed water out. Lower cooling to comfortable setting.
Jun 08, 2015 | Heating & Cooling
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Haier 5500 window unit, spits water into the room sometimes. Also, water "sloshes" around inside the fan area & is quite noisy sometimes. ? Thankyou for your assistance...
You will need to reposition the unit to where it will be tilted downwards slightly outside.
The water will then flow out the back and not spit into the room.
Jul 16, 2011 | Haier hwr10xc6 Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Panasonic a/c 'spitting' water out the sides.
your water pan is not draining and fillin up with water causing the fan to spray it around
Jul 12, 2009 | Panasonic Room Air Conditioner CWXC104HU
Why does my window air conditioner in my house spit water out of the front of it and i can also hear the fan blowing water around the inside of the AC?
It is freezing up. Change or clean the filter(s) and turn it off until it thaws. If this doesn't work the problem may be more serious. Usually this means it is low on freon. A technician will have to do this repair due to EPA restrictions on the refrigerant
Jul 08, 2008 | Heating & Cooling
Spits out alot of water!
It needs to be installed sloping slightly outside. It is not meant to be level. Use boards or whatever to do this. If this doesn't solve the problem the drain channel is plugged. Take off the outer case and look at the bottom there should be some kind of channel from in front to the back. Use a turkey baster or something to flush it. The back may be fairly deep to hold some water. Don't drill a hole. Some units keep some water in the back so the outside fan can throw it through the condensor to help cool it.
Jul 02, 2008 | Haier Mechanical Air Conditioner HWF05XC7
Split Unit Spitting water
Do you live in an area of high humidity? This could be your problem. The water that is coming off the evaporator and draining to the outside pan is building up and picked up by the condensor fan and consequently blown by the fan inside. If this is the problem the fix is to drill a hole in the pan to permit the water to drain from the pan. Be careful as to where the hole is drilled so as to not damage any component of the a/c. I would suggest at least a 1/4 inch drill bit be used to make the hole.
May 26, 2008 | Friedrich QuietMaster RS10J10 Air...
Haier hwr10xc6 Air Conditioner Logo
4,953 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
