Question about Toshiba Satellite A45-S250 Notebook
Bios which do i push so I could go to Bios thanks
    Sergeant:
  • 284 Answers
To enter the BIOS, press the Esc key when the Toshiba script shows up on the display. You should then get a message to press the F1 key to continue. Press the F1 key and you should be in the BIOS. The Boot sequence is on Page 2 of the Bios settings on many Toshibas. To get to page 2 press the page down key. Make sure you follow the screen prompts because your system may be slightly different.
Please rate this, thanks
Posted on Jun 25, 2008
How can I update the BIOS in my A45-Toshiba.
Posted on Aug 13, 2008
  • 25 Answers
To go Bios
just press DELETE+F2 button continously for few minutes..
then you find the bios setup
My acer aspire9410 disply is blank,i entered many time bios setup key F2 but it not showing bios setup page, pls help me to get in to bios page. before i tried lot one it was showing but it showing like...
-changeing bios-first restart computer then press[ f2] then get on key board use arrow key on key board go down you will see your boot log is on f2,change that on a f12, now push f10 to exsept settings now when asked restart computer then f12 then run windows under D:drive.
Feb 26, 2011 | Acer Aspire 9410 Notebook
Omnibook xe4500 long beep and now will not post bios. This happend when I was trying to boot to the DVD to reload the OS recovery disk. All the lights above the left side of the keyboard are lit up with...
screen never shows words, ever, does external screen work
at VGA port?
no bios does not just bug out , like ELVIS.
its ROM , ROW will not forget, (99.999999%) of the time.
good for 25+ years, by DESIGN.
unless humpty is pushed by geeks playing bios flash games.
this notbook is old , Pentium 4 , square screen , omg, old
512kb mem. ouch
HDD 30GB. (tiny)
first is what, try this
1: battery out. (big battery, ) take it out.
2: coin cell 3v not 2v, or its bad. replace coin, as all this old are bad.
3: power pack good. must put out full 19vdc voltage , does it? now.
4: BIOS hot keys work, (mine is ESC , key) is yours?
5 still no bios. does a flash light pointed at screen show data there?
yes/ no/. yes, back lamp burned out (or the DC/DC inverter card)
no screens, black screens still...
6: still dead, remove HDD, and DVD. drive. still dead.?BIOS> get BIOS working first. use the hot key.
remove all; easy things, even USB things.
7: remove all extra memory, RAM, if 2 sticks try 1. then run other by self. if runs now, ram removed is bad.
there is more, there are over 3million transistors there.
see black screen #1 here. goes into all steps, all paths for dead.
http://pcdied.com/
Apr 17, 2017 | HP OmniBook XE4500 Notebook
I just installed a Biostar Mainboard model#P4M80M7A in a new build and at startup, while most computers will go directly into windows, this one starts up and goes into BIOS and stays there until you push...
I would enter bios and go to advanced features and look at the first boot device. Make sure it's set to the Hard drive. Other than that, I'd check to see if your del key is sticky. That's the key that opens the bios setup.
Thanks Mark
Mar 11, 2010 | Computers & Internet
Vista and Ventrilo
this motherboard have till windows xp support and u have install vista but still no issu u have to download new bios updat from asus site for this board and get new updat of bios and once format & reinstall vista os again
Thanks
Jul 25, 2009 | ASUS M2N-E SLi Motherboard
Intel d945gnt bios won't load when power up...
there might be problems with the ram you are using.. try your friend's ram in your computer. if it works without the problem you specified , go for replacing your ram. if the problem persists contact us back. thanks for using fix Ya!
May 26, 2009 | Intel D945GNT Motherboard
Bios how to clear
Hi mdgsc,
You don't need to clear the Bios, what you need to do is open the bios, by either the delete key, or F2 key, or when your computer reboots, it should tell you on the first screen what key to push to get into the Bios setup. Once your in there, look for Boot drives, and change your boot drive to first priority your CDROM dirve, so it will look first at your CDROM, prior to your hard drive. That message is because it's looking at the hard drive.
Give a try,
Good Luck and don't forget to leave a rating based on my solution.
Thanks Mark
Apr 09, 2009 | Compaq Computers & Internet
Bios entry
Push delete when you start up your computer, keep pushing it until the bios loads.
Dec 16, 2008 | Intel Desktop Board D850MV (KD850MVPAK10)...
Recovery restore disk does not respond with my acer aspire 3000. it is just operating in safe mode
ok, don't worry, check your bios setup, place first boot device is cd/dvd, save your configured bios and out from bios setup.Ok insert your Recovery disk and restart your acer. Push any keyboard tuts if Any Question to boot via cd in boot process. Ok follow step by step discription in process recovery.  If you don't know how to inside bios setup, if you reseting acer look first process boot you will saw what's keyboard button you must push, ok good try, and don't forget to vote me, Thank's
Nov 03, 2008 | Computers & Internet
How to get my mobo to post cpu and gpu temperature.
You may be looking at a damaged MOBO, which could be the BIOS, or the temp sensors.
Feb 21, 2008 | Foxconn 6100M2MA-RS2H Motherboard
Toshiba Satellite A45-S250 Notebook Logo
452 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
