Question about Jl Audio E1200 Car Audio Amplifier
Have a jl 500.1 amp
When playing the amp sometime the amp dont play it show the power light green blinking and dont hear nothing out of my jl w6
  • heyomar Sep 30, 2008
    I have a 300.2 v2 amp that did the same thing, and have a JL W6v2
    does any one know the solution to this??
    my battery voltage is normal at 12.5 volts when its not turned on. not to sure about when it is turned on.. but anyways could it be the alternator???
  • Anonymous Mar 16, 2014
    blinking green light on jl xd600 amp
  • 323 Answers
I thought I would add, this can damage your amp, you definitely want to lower your gains on the amp or change the wiring diagram you are using on your subs.
http://www.jbl.com/car/product_support/SubwooferWiring/sub_wiring_diagram.aspx
www.onlinecarstereo.com is currently running a sale on the kinetic capacitors if interested. I just bought one of their batteries and it is doing wonders for my audio system.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20378
Posted on Feb 11, 2009
  • 160 Answers
For that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Posted on Dec 01, 2008
Ok i have a jl500/1v2 amp with 2 w6v2 subs and i haveing a problem dont no if the amp is two much for the subs becouse i turn the amp to get more tump and the subs pop and the yellow light filkes so i turn...
its real simple. your under powered.
your W6s RMS at 500 watts EACH and your sending em 250RMS (half what they need)
The 'pop' your hearing is the failure to supply enough power to draw the cone back in time and collides with the next wave of sound.
prove it?
drive a single W6 with your 500/1 bridged.
i'll bet your pop goes away.
long term, get another 500/1 or jump up to a 1000/1v2.
I also HIGHLY recommend JL's in-line audio cleaner. If i recall it was like 60 bucks but waaaay worth it. makes sure that theres no distortion in the source input to your amp(s), which...keeps your subs from trying to reproduce transients and delivers only clear signal to your subs void of all clipping signals. Its an active electronic compoent.
PS: if you are pushing 12W6's, i had the same setup once...I had W3s connected to my 500/1 and upgraded to the W6s...had the same issue your describing, and then got the 1000/1. happy ending.
May 03, 2011 | Jl Audio 500/1V2 Car Amp
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
I have a jl audio w3 that doesn't play or make any noise. I bought it brand new, never had been installed. Pressing the cone feels smooth and precise, so there is no signs of the coils being burnt out. The...
Id say take it back to where ever you bought it from and get an exchange. Have them test it there and see if it works. I have a JL W6 and have had JL's for a long time.To hear of something like this with a new JL is very rare. Just may be some kind of defect. Bring it back, get it tested and go from there.
Jun 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
Rca Connection
You need to check the shield ground on the head unit. The following link will guide you through the test procedure.
Shield Ground Testing
Jun 07, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1
Nine times out of ten if the amp smells burnt it usuallly is. Your best bet is to hook another amp to your system and see if you get sound.
Jan 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl Audio E1200 Car Audio Amplifier Logo
401 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
