Question about Sony DAV-FX900W System
PRESS POWER PROTECTOR
While watching TV, the sound "popped" off the speakers and 'PRESS POWER PROTECTOR" flashed across DVD component. Have tried the various troubleshooting options suggested in the manual, but still no sound thru speakers (brief sound bits in beginning when turn power back on each time and then silenced each time by the "popping off" of the sound. Still have picture.) Am giving up for now. Will try again tomorrow. Any other suggestions/solutions would be greatly appreciated.
  • PalmToadz Jun 25, 2008
    ** PUSH POWER PROTECTOR **
    I mistyped----my title & comment should read "PUSH POWER PROTECTOR" instead of PRESS. Sorry. Corrected version is below:
    While watching TV, the sound "popped" off the speakers and 'PUSH POWER PROTECTOR" flashed across DVD component. Have tried the various troubleshooting options suggested in the manual, but still no sound thru speakers (brief sound bits in beginning when turn power back on each time and then silenced each time by the "popping off" of the sound. Still have picture.) Am giving up for now. Will try again tomorrow. Any other suggestions/solutions would be greatly appreciated.
  • dusatkojj Jul 13, 2008
    I went on vacation for two weeks and unplugged my tv, dvd, etc. i did not unglug the rear speakers. When I got back I plugged everything in and tried to listen to the surround sound but the 'PUSH POWER PROTECTOR" flashed across DVD component. Have tried the various troubleshooting options suggested in the manual, but still no sound thru speakers (brief sound bits in beginning when turn power back on each time and then silenced each time by the "popping off" of the sound. Still have picture.) Any ideas?
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
Insignia 37 inch....no sound after lightning storm and HDMI's are not working
Dude! You fried it! Sound board can be replaced, but what else was stressed? Replace it, use a good surge protector, and turn the thing off during storms, light a candle and cuddle with your sweetie.
Jul 15, 2014 | Insignia Televison & Video
I have a sorround sound lg and im trying to watch a movie and there is no image. my tv says that i have no signal but the sound comess out. i dont know what to do.
Sound comes out because your player is working and speakers are connected to the DVD/VCD/BlueRay/ Home theater (what ever your player is). However, you may not have connected the video cable to the TV. (I think this is the case because, usually when you connect the video cable, LG pops up a message; something like: New input connected, Do you want to enjoy it with a Yes/ No option, which you can select using the remote. If you have connected the video cable you need to select the correct input in the TV. Click the input button on your remote. That will show you the various inputs, use the right/left arrow to scroll through the active inputs. If you are connecting an HDMI cable to connect the player to TV, select it. If you use A/V cable select it. If you are using a S Video cable, select that. If a component cable is used select that as your input. Once this is done correctly you will have signal. Hope this helps. Anil
Jan 21, 2010 | Audiovox Audio Players & Recorders
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Watching T.V. with speakers
Component 1 on the TV is probably an input, not an audio output. You need to find out if your TV has audio output jacks.
If I'm mistaken, and you are using audio output jacks from the TV, then you just need to press FUNCTION on your remote until the LCD display says "TV/VCR".
Apr 28, 2008 | Sony DAVHDX265 System
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
Sony DAV-FX900W System Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
