Question about Kodak Carousel 4600 Slide Projector
No light The light doesn't come on when the unit is powered up. The bulb seems to be fine. Is there any other check that can be done to isolate the problem? The fan is working on powering up.
    President:
  • Kodak Master
  • 412 Answers
If you know someone else that has a projector of that vintage, try swapping lamp modules! The lamp socket that the lamp seats in can build up material from arcing on the contacts and that material insulates the contact surface from the lamp pins. There are still parts (lamp sockets) available (www.micro-tools.com), but it may be more of a repair than you want to undertake. Consider buying a new lamp module on the web or finding a factory-trained repair dealer to make the repair. Good Luck !!
Posted on Jan 07, 2011
Testimonial: "Thank you Jim."
Interior. Light. on my 1995 ford econoline doesn't. work. it was. working. fine until. my starter burn out
Hi Hector:
The starter and the light should be two separate issues.
I'm assuming you have had the starter repaired.
For the light, check:
- is the bulb burnt out?
- is there power at the light fitting
- is the ground functioning?
- Is there power at the switch?
- Use a continuity/voltmeter to check.
Isolate the problem and you will find the solution.
Cheerfuls.
Aug 14, 2015 | Ford Cars & Trucks
My right front turn signal doesn't work, I have replaced the bulb the right rear works fine
You would check the socket with a test light or meter to see if you have power and ground. If no power, the turn signal switch would be the next thing to check.
Jan 25, 2013 | 1999 Toyota Corolla
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
LIghts don't turn on when door opens.
Start by checking the door switch that activates the lights. It may be stuck or have a loose wire.
Dec 18, 2011 | Sub-Zero 601R
I have an 06 Dodge Charger. My rear passenger side turn signal isn't working. The bulb seems to be good because the tail light still works and it's the same bulb. What could be the problem here?
the turn signal and the brake light,, not the tail light section use the same filament, so be sure that the bulb is ok, have someone apply the brake,, if it goes on your bulb is fine and you have a different problem than the bulb , on the newer vehicles with the glass end on the bulb and the 3 wires ( sometimes 4 ) the wire gets smashed flat against the glass and doesn't make a good contact , remove the bulb and very gently pull the wire up away from the glass end, see if that works, if not, do the same thing to the socket end
Sep 03, 2011 | Dodge Charger Cars & Trucks
2003 Highlander passenger headlight works off and on. Seems to be connected to the temperature on the rear view mirror. When the light doesn't work, the temp is a crazy number. Are they connected? ...
Try the bulb itself. You can check it with a voltmeter set to continuity. Check the harness for a poor ground connection near the bulb socket. It will be a black wire under a screw head on the chassis. If nothing out of the ordinary is found, replace the headlight relay for that side. Each headlight has its own relay.
Jun 27, 2017 | 2003 Toyota Highlander
This unit has never operated properly , the bulb has been replaced with a proper bulb and a check of the line cord with an Ometer show a partial circuit when the fan-light is turned on.
You should never check ohms with power on.Also,unless the component you are trying to read with power off and is not completely isolated,you will always read some sort of ohms.
Feb 11, 2011 | Heating & Cooling
A/c shut down /how to reseset
Reset the power with a 5 min gap on the outdoor isolator and indoor isolator (if applicable) then return with any fault codes/light flashing sequences which will be the fault coce, if it occurs again :)
Jul 04, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Side lights won't come on
you have an electrical shortage. Have OBD analysis done and preform probe test lamp procedure on fuse box
Apr 25, 2010 | 2001 Volvo V70
Headlight not working fuse good bulb good no power to switch
i had the same same problem with my 1992 vulcan 750. more than likely it is your reserve lighting devive located on the right side battery box. have you had a problem with your regulator/rectifier lately or a power surge of some type?
May 19, 2009 | 1992 kawasaki VN 750 Vulcan
Kodak Carousel 4600 Slide Projector Logo
133 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
