Question about SanDisk Sansa e250 MP3 Player
Sansa e250 is not showning usb plug in
I have win xp , wmp 10 in my computer .when i am connecting USB plug in not showing .How I can transfer audio n video files into my player .Plss help...do I need any driver for detecting the player ..
  • 8,596 Answers
Yes, you need a driver - I hope you have your installation Cd b/c Sansa has taken the driver off of their website. Look at the previous solutions for this player in Fixya, b/c this questions has been asked many, many times and people have offered a few third party websites where you MIGHT be able to find the driver
Posted on Jun 25, 2008
I just bought a Sony NWZ E354 mp3 player. When plugged into my usb front main port, computer sees it as MTP device but disables it. I' running Win XP Pro and WMP 11. Take same player and its...
I upgraded my usb drivers -- I have windows xp pro -- i think they use all the same -- I used Realtek USB 2.0 card reader drivers. ( http://bit.ly/qeofyZ ) plugged it in (NOT in the front, but the back)_ & it recognized it after going to start, computer as "walkman" -- did a right click explore & all the data/music was still on the hard drive. then it showed on the walkman that it was charging & the battery was dead. i was previously using an AC usb adapter (plug in the wall) & it didn't seem to be charging it correctly -- so the computer works out for me & will only use that from now on -- fully operational.
Jul 14, 2011 | Sony Ericsson Audio Players & Recorders
Tip
My sansa e250's USB port dos not shows up on MY COMPUTER/ON DRIVE :F and when i...
One of the typical problems people run into with MP3 players is that they lose the software that came with the player and can't figure out how to get music on or off the player. So here's a quick how to. This will work with most brands of MP3 players, or even USB flash drives.
First you need to plug it in to the USB port, if you are running anything newer than windows 98 you won't need a driver. Double click on my computer and it shows up as a removable disc(usually drive letter f:), double click this drive to open it as folder. This folder will show you all directory's and files on your player, here you can delete any songs on your player by finding the file and deleteing it. From here you can also put your music onto the player by copying and pasting your music files from your hard drive. If you are not sure where your music is located you can run a search by clicking START>SEARCH>FOR FILES OR FOLDERS (if you are running XP click pictures music or video, check music then click search, each file will have it's location in small print below it's name, or you can right click each song and hit copy, then go back to f: drive and right click and hit paste, you can copy more than one). Hope this helps.
on Jul 08, 2008 | SanDisk Sansa e250 MP3 Player
My pc window can not recognize mp3 player
Hello
Connect your Sansa MP3 player to more than one USB port on your computer. Ensure that your computer USB port is not corrupt or disabled by testing at least two available ports. This is especially useful when you possess no other USB-based equipment.
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled.
Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Scan your computer for new hardware changes. From the Device manager, click the "Action" menu and select "Scan for hardware changes" while your Sansa MP3 player is connected. Allow your computer to attempt to find any physical component recently added in the event it failed to previously detect it.
Connect your Sansa player to a different computer. Test the connection on a different system's USB port to verify that the Sansa device's own connection has not been damaged. Inspect the USB ports on the computer in question as well to eliminate the possibility of both systems having problematic USB ports.
Change your Sansa MP3 player's USB plug. Sometimes the head of the plug may lose contact with the appropriate circuits. Obtain a secondary USB port at your local retail store and test it on an updated computer system.
Nov 14, 2010 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
Jun 17, 2009 | SanDisk Sansa Clip MP3 Player
I don't know how to load music from the internet to my new mp3
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Intel1.gif Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data1.gif folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 28, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e250-MTP Driver
MTP driver kit is located here.
MICROSOFT
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
Computer won't read mp3 player
Same exact problem! Sorry I'm no help > My Sansa e250 has been working fine for about a year. No problems, I can charge and sync it. > Now all of a sudden I have a problem. > My PC does not see the Sansa. Why? > I enter recovery mode. I see: > Welcome to "Recovery mode" Please connect USB Cable. > I connect the usb cable AND NOTHING HAPPENS! > Yes I read all about recovery mode on the internet. I tried it in both MSC mode and MTP mode. > How can I get my computer to see the sansa? > If my PC can not detect the Sansa then I cant get a firmware update now can I?
Jul 23, 2007 | SanDisk Sansa e250 MP3 Player
WMP won't detect my MP3
See if this helps: -Close all programmes on your computer. -Turn off your Sansa e250. -Attach the cable into the USB port of your computer before attaching it into the actual e250. -The scroll wheel on the Sansa should have turned on by now. -Then it's just a matter of waiting for a few seconds. -Try opening Windows Media Player to see if it detects your device. Otherwise, be patient. Goodluck.
Mar 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
