Question about Dometic Rooftop RV Air Conditioner
Front unit high cool and high fan not working
The high cool and high fan does not come on now. However it sounds like the compressor on high cool does come on. Or at least it sounds like it does. Sounds like a hummm. It kicks on a minute or so after I turn on the high cool. But that is all it does. Low cool seems and low fan seems to work fine. Rear unit is working fine
  • gitzit1 Jun 25, 2008
    Do you think it could be the fan capasitor?
    Novelist:
  • 121 Answers
I would recommend you take this unit to an RV service center. The issue could be due to many variables. It could be something as simple as the controller board relay or a low freon level. You may also be able to call a regular home heating and airconditioning shop to take a look at the unit. Keep me posted and if you found this solution helpful please rate it when you get a chance. Good Luck - Tech101
Posted on Jun 25, 2008
    Master:
  • 848 Answers
Just replace the fan ..... its seems there is some voltage problem
  • gopinath pasupathy Jun 25, 2008
    if your fan replacement does not work .........it looks like a control problem with the thermostat or relay board (if you have a wall mounted thermostat). If the compressor is coming on, then you need to look into the airflow of the unit. Whether or not the compressor is coming on, you need to check the voltage. Like every appliance on board, the air conditioner needs adequate power to operate. If the voltage is 110 volts a.c. or below, the effectiveness of the unit will start to suffer. After verifying correct voltage, we need to look at how the air conditioner does it's job- it requires adequate air flow over both the inside (evaporator) and outside (condenser) coils. If the air filter is clogged refrigerant will not be able to pick up enough heat from the inside air, and if the condenser coils are blocked by leaves, it will not be able to give off enough heat to the outside air.
    also check this
    the evaporator coils probably need cleaning . These can be seen when you remove the air filters, and possibly the inside air box. Likewise, the condenser coils can be seen after removing the upper shroud.
High pressure unit disable
Hose off compressor until cool, remove cover, manually press contactor. Sounds like bad fan motor, fan not working. Compressor overheating
Mar 02, 2017 | Heating & Cooling
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
We installed a new TCJD36 (3 TON) unit with new A coil. The unit works fine from morning until 4:30 PM. from 4:30 PM to 9:00 PM the compressor does not come on. Inside fan goes on and outside unit fan...
This really sounds like the unit is over heating the compressor to the point of triping the internal high limit switch and just taking that long to cool off before it resets. If it continues to do this go outside and run your water hose over the compressor for at least 30 minutes to cool the compressor down and see if it starts for you then. If so then your unit could be over charged and creating very high head pressures!
Aug 11, 2010 | Goodman CLQ36AR49 Air Conditioner
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
A/c issue
Could be a couple things - one, if the fan switch for the AC condenser is not working, it'll keep the AC from kicking on, but that's usually seen by the compressor not coming on. When you activate the AC, do your RPM drop down at all? It should. If it does, the compressor is kicking on and you probably have a problem with the expansion valve, which is what flash chills the air. The car is pumping freon around but it's not cooling enough to cool the car. That's likely an expansion valve problem.
If you turn it on and the revs don't dip down momentarily, the compressor isn't coming on, and it could be the fan switch underhood or the AC relay.
Aug 29, 2008 | 1998 Volkswagen Jetta
Dometic Rooftop RV Air Conditioner Logo
138 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
