Question about Dymo LabelMANAGER 350 Thermal Printer
Fonts too small
Can you please advise me on how to change the font sizes on my Dymo 350 labell maker? at the moment the fonts are too small to read.
  • Anonymous Jul 10, 2008
    unable to change font size can'y locate manual so flying blind
    pax.
  • Anonymous Mar 20, 2014
    we need to change font size
    Problem Solver:
  • 6 Answers
Your instruction manual will tell you. However, there's a "Code" button that has to be pressed at the same time as the "Font" button. (Code button color should match the color of the Font button.) Keep pressing as it cycles through the font sizes (you'll see the arrow move on the screen). When you get to the font size you want, release the buttons and you're good to go!
Posted on Jun 25, 2008
Label maker font size
You change the font size on the computer prior to printing.
Jan 08, 2014 | Dymo LabelMANAGER 350 Thermal Printer
How do you increase/change font size on labeler?
To set the font size
1. Press Format
2. Select Font Size and press }.OK
3. Select the desired font size and press }.OK
The font size indicator on the display changes as you select font sizes.
Jun 22, 2011 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
How do you change the font and size on a dymo letratag?
Aside from changing the size, printing as big or small and using symbols, the LetraTAG does not offer various fonts. This model is pretty basic and has the one font and that is all.
The manual can be found at this location:
http://www.dymo.com/media/UserGuides/QX50US.pdf
May 16, 2011 | Dymo LetraTAG Thermal Label Printer
How do I change the font size on a Dymo LabelManager 350?
Please follow this instructions
Changing the Font
Six font are available for your labels:
Arial Narrow, Arial Normal, Arial Wide, Times
New Roman, One Stroke and Frankfurter.
When you specify a font size, that size applies
to all characters on current page.
To set the font
1. Press the Font key.
2. Use the arrow keys to move to the desired
font and then press OK.
Also here the link to the manual for further instructions.
http://global.dymo.com/img/compel/Q5S_A-MZSgeJZGJ73tJmbPunig_yx_v1.pdf
regards
Mar 25, 2011 | Dymo LabelMANAGER 350 Thermal Printer
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
I have a LabelMaker 450D and I do not know how to make the font a smaller size. I want to print a label that has a name in a larger size and a line underneath with the job title that is in a smaller size...
Hello. Here is a free downloadable manual for your labelmaker. http://www.dymo.com/media/UserGuides/LM450D_US_931764.pdf
Turn to pages 9-12 to learn how to change fonts and how to do multiple fonts and underlining all at once.
The label maker remembers the last feature
selection made so that each time you enter one of the
feature menus described in this section, you are
positioned at the last item selected from that menu. J.
Aug 07, 2010 | Office Equipment & Supplies
Saving/printing different font size
Try to do again a complete reset, then set all settings again to big fonts and try saving.
Ensure also that you use Dymo original labels, they have a tag at the back, non original do not have it.
Sometimes with non Dymo rolls the machine lose settings.
Sep 13, 2008 | Dymo LabelPOINT 300 Thermal Printer
Dymo LabelMANAGER 350 Thermal Printer Logo
1,472 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
