Question about Philips (JR4DVDRWK/00) DVD+RW Burner
Phillips DVD-RW SDVD 8441
I have a Gateway notebook with a Phillips 8441 Disc Drive. I installed Vista Ultimate and it recognices the drive but it will not read any disc.
I tried uninstalling the driver and installing the one picked by windows ans still, finds the drive unit but cannot read any disc. Is this common and is there a solution?
  • vinderviper Sep 05, 2008
    reemove old driver
  • Anonymous Sep 06, 2008
    I also have a Philliips 8441. It also does not read discs, in addition the CD tray will open unexpectedly during operations
4 Suggested Answers
  • 1257 Answers
SOURCE: DVD Burner won't install drive
Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on May 26, 2009
SOURCE: My Philips DVD 8820 Drive does not read any discs.
This can happen if the CD you place in the drive might not be readable or it is corrupt.
Or your Drive needs to updated with firmware update.
check with your manufactures website for updates.
Posted on Jul 10, 2009
  • 111 Answers
SOURCE: gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
I have an ACER Extensa 4220. My OS is Windows 7 Ultimate 64-bit. My problem is: After OS installation the CD/DVD drive is working well--able to read disc in general, able to install softwares or driver via...
Purchase a new (or used) disk-drive that is compatible with your Acer notebook.
Remove the current disk-drive, and set it aside.
Connect this "alternate" disk-drive, and install Windows onto it.
Then, test the CD/DVD drive -- if it still gives problems, then you have a "hardware" problem with the CD/DVD drive, and trying to make any "configuration" changes within Windows will have *NO* effect.
Jun 01, 2011 | Acer 4220-2346 Notebook
My DVD-rw drive can't install the DVD programs
Make sure the disk is for version 2.5 if you are using Vista. You can download it from the web.
Feb 15, 2010 | Lexicon Alpha Personal Recording Studio
Need new DVD-rw the one that came with notebook M 6843 died it just spins and says no disc installed
there is one screw holding the drive in either on the bottom at the back of the dvd drive or under the keyboard. Once you remove it find the model number and check ebay.Order one and when it comes just slide it back in and screw it down
Jul 16, 2009 | Gateway M-6843 Notebook
Disc Drive won't read after upgrade to Vista Ultimate
I had a disc Drive that wouldn't work for a while. There are a few things that could be wrong. The first thing I would try is to make sure it's pluged in all the way to both the Motherboard and the Disc Drive. Maybe it wasn't secure in there and when you bumped you computer just a little bit, it got unpluged. The wire connecting the Disc Drive to the Motherboard is probably your thinkest wire, can't miss it.
this next thing I would try is to delete the driver for your Disc Drive and then restart your computer. It should detect it automatically and have it running correctly.
If all else fails, go to Google. Type in the name of your Driver and search for an install that is supported on your operating system.
Jul 07, 2009 | Acer (4432A-002) CD-RW Burner
Optiarc DVD-RW AD 7560A - well recording CD-ROMs, but not DVDs
i had the same problems so i updated the firmware for the cd/dvd drive and now its working perfectly
Jan 01, 2009 | Sony Optiarc AD-7170S Burner
Upgrade to vista ultimate
If you have a full version of Windows Vista Ultimate, you can just insert the DVD when you logged in your laptop and go to Computer(My Computer) and lauch the installer for Windows on DVD icon (Double Click DVD icon). It will give you the main window for installing Windows and along the way, you should find an Upgrade option. Click that one and it will install windows Ultimate on your system. It Will not format the laptop but installer will just add system files and features to the laptop to run Vista Ultimate.
**If you haven't purhcase a Windows Vista Ultimate Disc, check this link to to purchase just an upgrade Disc (only) of Vista Ultimate.
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
An upgrade disc will also not format the laptop instead it will just install additional features and add additional files on the system to run Windows Vista Ultimate
Oct 28, 2008 | Sony VAIO Digital Studio VGN-AR320E...
Hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
Disc drive will not recognize blank discs.
let's make sure that's a DVD RW disk shall we? check the front and make sure it says DVD RW..if it's DVD R, then it can't write.
Mar 17, 2008 | Gateway 7330GZ Notebook
Lite On LH-18A1P DVD RW
I have two LITE-ON DVD DRW LH-18A1P on drive (E:) and drive (F:) It has gone from everything working great to not being able to burn a DVD. When placing a DVD into either (E:) or (F:) it shows up in my Window's Explorer as a CD drive.... Only allowing me to burn a CD in these drives.... Can play past burnt DVD's though in both both drives.... hve tried a couple of different brand disc, LG and TDK and get the same message appears 'to please insert a dics', need help I do!!! lcs2
Running Window's XP
DVDMy LITE-ON DVD DRW LH-18A1P
Oct 09, 2007 | Lite On LH-18A1P DVD RW Dual Layer Burner
Philips (JR4DVDRWK/00) DVD+RW Burner Logo
1,401 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
