Question about Dual XDVD8181 Car Video Player
Dualav bypass e-brake
I have a dualav in-dash dvd player and im trying to by-pass the ebrake feature. now ive tried the code doesnt work, and i attempted grounding the wire and it worked for about 10 minutes then when i shut it off and turned it back on it wouldnt work, i just had the blue screen+audio. its still grounded;however, theres nothing. help
  • 4 more comments
  • big rims Jul 04, 2008
    i have same problem with mine it sucks cause i know this deck works mine is the xdvd700 daul help
  • curtisray Jul 10, 2008
    i have tried to ground the bypass and will not work i would like to by pass this
  • tjdlo Aug 20, 2008
    i have a dual xdvd700 i had it grounded and it worked the first night, then i shut it off and it wont work now. i have tried all the codes and it doesnt get me anywhere. how can i bypass the ebrake so i can watch? i am in a 99 tahoe
  • dan2fee Mar 20, 2009
    What kind of toggle switch? Can you give me an example or tell me which one you used? Thanks.
  • juangsalazar Mar 24, 2009
    same prob
  • ogsirsnake May 11, 2010
    im trying to bypass the ebrake feature but i havent had any success could you please tell me how i bought from someone,and if there is a code he did not give it to me.
Install a toggle switch. i did it and it works..........
Posted on Mar 12, 2009
    Problem Solver:
  • 8 Answers
You have to toggle swicth the ground, make it think the brake is on
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
E brake bypass think this will work?
Go on amazon.con type in micro bypass and buy the 3 wire relay about $10-12 and fallow directions included
Alpine screens may require a different bypass also found on Amazon
Mar 18, 2017 | Clarion VRX785BT Car DVD Player
How to by pass the e brake wire
at this time there isn't a code bypass for this model. the easiest thing to do so that you can play video while in motion. is to put a toggle switch on the parking brake wire of the dual screen. then do the ebrake pattern on the switch instead of the ebrake in the car
1. disconnect the parking brake wire of the dual from ur ebrake wire in your car.
2. take your 2 wire toggle switch and connect one wire to Ground(metal)
3. take the other wire and connect it to the parking brake wire of the dual screen.
if i remember correctly, the pattern for the dual screens is.
1. starting in the off position.
2. on for 2 secs
3. off for 2 secs.
4. then on .. the the video will show.
hope this helps
Oct 04, 2009 | Dual XDVD8181 Car Video Player
Parking brake by pass for my VW Jetta
on your main screen, change your source to "A/V In".. you should get a black screen. Touch the upper right corner of the touch screen and it'll pull up a number menu. Type in "7253" then hit OK. from there, there's a choice that says "brake" hit the right arrow till it says off. Then you're off and runnin SON!
May 08, 2009 | Jensen VM9510 Car DVD Player
E- brake by-pass code
This is the best bypass method for the Dual XDVD8181. Althoug i am not sure if it works for any of the similar models b Dual. My guess it will.
1) Groun the emergency brake wire.I used the radios black groud wire.
2) Insert a DVD and let it play until you hear the sound.Copied DVDS will not work for this.
3) Press STOP on the remote TWICE.
4) Using the remote enter 26604 and press enter .If done correctly you should hear it beep and the video will be viewable.Good Luck.
0
Mar 23, 2009 | Dual XDVD8170 Car DVD Player
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Help need bypass code or instructions
There should be an extra wire on your wiring harness, labeled for the e-brake light. Find that one. On my Jensen, it's a peach colored wire. In your manual, take a look and see what it says is required for activating the DVD playback feature. If you simply have to pull the brake handle to make it work, then yes, just ground that wire and you're in business.
On my Jensen, there was a sequence that had to be done - the brake had to be applied, released, and reapplied for it to work. What I did initially was to ground the wire and put a switch inline on it. To simulate setting the ebrake, I'd close the switch (completing the ground), then flip it open to break the connection (same as releasing the brake), then flip it back again, and the DVD would play.
I found a little while ago that there is a hidden feature menu on the player that allows the e-brake sequence to be bypassed with a code, which I put in and now it's not an issue.
Take a look at your instruction manual and let me know if it just has to have the e-brake on, or if there's some sort of activation sequence like my Jensen has, and I can firm up the answer.
Dec 26, 2008 | JC Whitney - Pyle 7" Tft/lcd In-dash...
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
Dual XDVD8181 Car Video Player Logo
439 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Neville Ward
Level 1 Expert
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
