I inserted my MobileMate SD Plus disk into my usb port on my computer. I inserted an sd card according to instructions. a disk icon appeared under My Documents but nothing happened when I inserted my sd card.
  • 100 Answers
*take out ur inserted sd plus disk and again insert according to instructions
* restart your system
*still not working go to bios check wheather setting are ok
*contact to the manufacturer
Posted on Jun 25, 2008
How to download an avchd video from an SD Transcend card
1) Plug the SD Card in you PC's card reader,
2) Open an Windows Explorer (WIN-E) window and locate your SD Card,
3) Browse the SD card and find the video file you want to COPY (why did you say DOWNLOAD ?),
4) Copy (CTL-C) it, and paste (CTL-V) it on your local disk !
Aug 27, 2014 | SanDisk MobileMate SD Plus 5-in-1 Media...
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
Micro sd 2gb card, not read.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
I just got a new 8GB SanDisk Mobile Ultra microSDHC card for my phone. While it seems to work in the phone, this is not a whole lot of good, as it doesn't work in either PC I've got here (both running...
r u sure your pc is usb 2 not usb 1 coz some pc will not read usb 2 if it has usb 1 that is wot i found with my adaptor so check that out if not tri a diff usb slot and if it dont work then tri and udr a diff adaptor
Aug 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
Locate local source for usb cable and user manual
Don't ever buy another USB cable for any camera MariamAli. Buy San Disks mini card reader MobileMate SD+, plug your mem card, SD,SDHC, or MicroSD, into it, then plug MobileMate directly into your USB port.
Saves lugging around a bulky, and unique, USB Cable and saves on your camera battery power, that otherwise is needed to power USB Cable download from camera.
Available at RadioShack, Staples, and most anywhere SD Mem Cards are sold. $15 it think.
Apr 06, 2008 | Kodak EasyShare CX7330 Digital Camera
Micro sd
let me understand this...to erase from it, just pull it up after going to my computer and finding the usb port it is in and delete anything that is on it....
now you 2gb memory/card/stick is new? is this a memory card for your camera?
If your sd card is plugged in to removable disk k and you send your photos to it, then they should be on there. That is all you have to do is select, send to and choose disk K.
if you want to make sure they are going there, have disk K open and running at the bottom, it will not hurt a thing.
Hope this helps
Feb 12, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
Micro sd
Once you plug it in, it should appear under "my computer" as removable storage. From there, you can right-click on it, and perform the format, etc.
If you want to copy to it, you can either copy / paste the file from to the card, or just drag the file to it.
Jan 10, 2008 | SanDisk MobileMate SD Plus 5-in-1 Media...
Sandisk multi card reader
if you are using a cord and usb port it sounds like your usb port is loose and not holding on. Try plugging it into another port maybe on the back of your computer.
Let me know if this works
Dec 14, 2007 | SanDisk MobileMate SD Plus 5-in-1 Media...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
