Question about Compaq Presario Notebook
Cleaning ok i use my laptop A TON and i just wanted to no if i could get it cleaned and fied, the key board, inside is gunky, the place were the screen meets the main body is busted, and id like to clean the memory and all that stuff, get rid of viruses, jsut like restore it to new, can u guys do that all? oh and some keys came off i think its presario c300 is on the bottm altec lanisng on the from its a compaq
  • buffalochip3 Jun 25, 2008
    im almost sure that they can but im not sure
    Sergeant:
  • 284 Answers
Depend on city and state youre in you can prolly find a place near you. if you look in the yellow pages. no yellow pages??
you can ask your local electronic store.
i could do it myself but im in california.
Posted on Jun 25, 2008
My acer asipre 4739z laptop starting after a few minutes not work. fan is running battery is ok
Please describe a list of events that takes place from the time the ON button is pressed until the screen goes OFF. Attach an external monitor and press the Function key with the screen key to transfer video. If monitor responds the video is OK but screen is BAD. Then replace Screen. If Monitor does not show video then problem is probably a thermo problem. To correct video chip overheating do the following; First ... Remove Battery. Remove CPU and Video Heatsink and Fan. Clean dust and lint that is blocking airflow in heat transfer grill. Clean dust from inside fan. Clean old heatsink grease from Heatsink and from Video chip and CPU. Apply fresh High Quality Heatsink grease evenly but sparingly to chips. Replace Heatsink following tightening order to spring screws at CPU. Replace covers ... and start.
Aug 30, 2013 | Acer 6-cell Battery For Aspire 4739z,...
Clean my laptop keyboard stisky
LOL, you shouldn't eat and drink over your laptop. Count your blessings that you didn't shorten your motherboard out. The best way to clean it is to probably take it apart from the computer.
Remove the power cord, remove the battery, then turn the laptop over and start removing screws from the bottom. Look inside the battery case and there might be screws there, specifically there might be some with the icon of a keyboard. Once you have the screws removed, turn the laptop over and open the lid, then pry off the strip that is over the keyboard just under the lcd screen. Once you remove it you might see more screws that hold the keyboard in place so remove them. Once all screws are removed, lift the keyboard gently because there will be a cable underneath it. Remove the cable that is attached to the keyboard and then you can clean it. I would use something like a toothpick or Q-Tip cotton swab and maybe some rubbing alcohol. You'll have to hold keys down that are around the key you want to clean to get under the key you want to clean that is stuck. Once you've cleaned it press it repeatedly to make sure it does not stick.
Apr 18, 2012 | Computers & Internet
How do I take off teh keyboard digits to clean underneath - after spilling melted chocolate on some keys they are stiff and sticky.
  1. Remove the old keyboard key by putting the tip of your fingernail underneath the top right of the key you want to clean.
  2. Lift the key upward to remove the key.
  3. Push the hinge into place on the keyboard, and put the rubber spring piece into place.
  4. Align the cleaned key on the keyboard so that it is in the correct place.
  5. Push the key firmly in place, and move it slightly around until you hear a clicking sound.
Feb 07, 2011 | HP Pavilion dv6000z Notebook
My nb100 laptop. keyboard some keys not working.
There are various ways of solving this issue. Some of them has these broad explanation.
Problem #1 - My Laptop Keyboard Keys Not Working
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
The complete process will take you a maximum of 2 hours. Cleaning and lubricating the laptop keyboard in the above prescribed manner once a year, can prevent many 'laptop keyboard not working' situations.
Problem#2 - My Laptop Keyboard Types Wrong Characters
When your laptop keyboard types wrong characters, it is because of a software problem and not a hardware one. If you accidentally press specific keys on your keyboard, it can activate a particular function responsible for the problem.
  1. Select the control panel option
  2. Click on ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
  3. Choose the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
  4. Make sure that all the check boxes in the window are unchecked and repeat the same for 'Switch to..... (Keyboard Type)'
  5. Click ?'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
Problem#3 - My Laptop Keyboard Types Numbers Instead of Letters
This is another laptop keyboard problem due to some software issue. It is possible you may have enabled a digital lock unknowingly.
Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem
Dec 20, 2010 | Computers & Internet
Hp Compaq 6735s I clean it with multi purposes foam cleanser & the key board stop working since yesterday & I tried cleaning lt with a spirit
use of spirits in a keyboard is not recommended, it will eatup and destroy the rubber compounds that make the keys work. It can also damage the electronics inside. Find some canned air, try to dry it out as best you can with the air between the keys. Then try not to use it until it comes back to life. Until then try a usb keyboard in its place. Worst case scenario you will need to replace the keypad of the notebook. Its pretty easy fix though. Best thing to clean keyboards is canned air and windex on a paper towel for the key surfaces only. hope that helps. cheers
Aug 30, 2010 | Compaq Computers & Internet
Same problem. Stinky, moldy, gunky. Clothes won't clean.
First take a gallon o bleach pour it in on hot and run,then from know on after washing leave the door open so it can dry out and not mold between loads.
Nov 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Acer 240 laptop keyboard took sip of coke
Proper cleaning and lubrication as described here will restore your laptop keyboard to the snappy and smooth performance it had when new. This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive. This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE
IMPORTANT: Make a keyboard map so you know where each key goes.
Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.
CLEAN KEYBOARD
Do this well...... you will be wonderfully rewarded
Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves.
Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol.
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease.
Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely. LUBRICATE KEYS
Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD
Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry.
Alright, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
Place all rubber components into the keyboard.
Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place.
Install the rest of the keys by aligning and firmly pressing down.
CONTRATULATIONS, you now have a squeeky clean keyboard!
Jan 12, 2009 | Acer TravelMate 240 Notebook
My laptop arrow key is automaticaly press
Looks like your arrow keys are stuck and needs some cleaning. I suggest you to take it computer center where they can remove and clean buttons. Laptop keys are littlebit difficult to remove and place them back.
Dec 09, 2008 | HP Computers & Internet
Dvd player
at first clean the lence eye,but not ok then change lence rebon wire >change lance> loading ic(cheeps) ok> chek power supply board. sushil91077rajbanshi@rediffmail.com
Nov 14, 2008 | Compaq Presario C700T Notebook
I have to keys that will not type at all sometime the g works after hitting a couple times the t and Y don't work at all laptop keyboard my 7325GZ
hey there angles821
you may think that you have a faulty keyboard but thats not true...
you maight want to have the keyboard cleaned from the inside and have the rubber checked if its still ok. sometimes this things happen to laptops...
Apr 08, 2008 | Gateway 7330GZ Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
