Question about Janome D'cor Excel 5018
Won't stitch properly
The bobbin is not moving properly when I stitch forward or backward. The bobbin thread bunches up under the fabric and the top thread does not catch so therefore does not stitch. It sounds like the bobbin holder is catching on something. I've cleaned out all the fluff from underneath the bobbin holder but that did not make a difference.
thank you
  • TLAbrams Nov 01, 2008
    It will stitch the first 2-3 stitches and then gets jammed! Very frusterating. I have also tried taking the foot plate off and cleaning and re-positioning everything, still not working though. I've sent a question about it to the Janome website but have not heard back yet. Im going to try taking my machine to a store to repair it.
  • 749 Answers
Ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
    Habit-Forming:
  • 84 Answers
Your bobbin may be in backward, some are clockwise other are counterclockwise check your manual, be sure it is threaded through the bobbin case correctly as well.
Posted on Sep 27, 2014
  • Janome Master
  • 1,388 Answers
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=0&prdid=0&smid=23884&mthid=1&mpsaugid=541e3da8-c9d3-4504-9da5-f8ed5ebb8fcf
Posted on Nov 28, 2011
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
I have a Singer Stylist Model #7258.Serial #H10229C25810334. When I'm sewing,the top stitch is perfect but the bottom stitch comes out like backward C's. How does that even happen!????
Check your stitch sample. Is it actually the top thread showing under the fabric, or is it really the bobbin thread. Generally, thread problems under the fabric are an upper thread problem. Thread issues above the fabric is a bobbin issue.
Try a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread.
Remove the bobbin, check that it is wound smoothly, and install and thread the bobbin case making sure the bobbin spins the correct direction.
From that point, there may need to be some tension adjustments required.
Understanding Thread Tension Threads
If the problem continues, you may need to have it serviced. Perhaps there is a burr or snag somewhere that is interfering with the thread in the thread path.
Oct 21, 2017 | Singer Sewing Machines
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
I have a elna lotus sp, it keeps bunching up underneith, ive had it working. I've changed the needle , it's starts sewing then stops due to it getting tangled ,
try another needle-- one for the fabric being sewed
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
make sure the bobbin is inserted into the bobbin case correctly
make sure the bobbin is turned the correct way in the bobbin case
Mar 09, 2016 | Elna Sewing Machines
Top thread too tight. Bobbin thread too loose. Bobbin thread bunches up underneath material. The feeder teeth can not feed material through
first thing first - thread inside bobbin should be tightly wound in. Insert bobbin into bobbin case and thread through slot and under the spring. Spring has small screw which regulates the tension. Hold the thread like yo-yo and jerk a little down-up. It should drop just a little (not run down) - that is usually required bottom thread tension,
if not, regulate with the screw. Set top thread tension 3 and sew. If still looping under, increase the top tension higher till the looping disappears. .
Nov 03, 2015 | Sewing Machines
When i run a straight stitch, the top of the fabric looks well sewn; the thread on the bottom of the fabric, however, bunches up-it looks nothing like the top stitch.
Is it really the bobbin thread that is bunching under the fabric, or is it really the top thread that is creating loops and "bird nests" under the fabric???
Rethread your upper thread. BEFORE you thread the upper thread, be sure to RAISE the presser foot. This releases the upper thread tension disks so the thread is firmly seated in the tension disk.
If it continues to be a problem, then the upper tension needs to be tightened. Adjust slightly, then test. Repeat until the upper and lower threads meet in the middle of the fabric.
Sep 24, 2015 | Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
Sewing Machines Logo
954 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
