My son has a Nintendo DS that had the same problem. The battery was no good--wouldn't take a charge. We bought a new battery and that didn't fix it either, so don't waste your money. All we can figure is he must have dropped it or something happened while it was in his backpack (kids!). We tossed it and got a new one. I'll be upset if it's something simple!! Good luck to you.
The majority of laptops will display a solid green, blue or
purple battery light to indicate that the battery is fully charged. Most
manufacturers indicate that a laptop is in the process of charging by
displaying a solid or blinking green, orange, blue or purple light. If
your battery indicator light is green, blue or purple, the battery is
probably functional, regardless of whether the light is blinking. If the
light is solid orange, the laptop is probably in the process of
charging.
Battery Error Coneventions
Many battery manufacturers use rapidly blinking lights to
indicate that a battery's charge level is low. In general, a laptop will
rapidly blink orange or red when its charge drops below a certain level
until the computer is plugged into a power outlet and charged. If your
laptop's battery indicator continues to blink rapidly in orange or red
or if it remains red even when it is plugged into the charger, it
indicates a problem with your battery or the charger.
please read and execute the commentaries. God bless you Charging Conventions
charging.
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
Plug the charger into the wall. Plug the other end into the spot on the PSP with the yellow outline. Check for an orange light. If it's on, let it charge until the light turns off. It it's not on check connection. If it's still no charging, take out the battery and put it back in. If it's still not charging remove the battery and try to turn it on. If it will no start, your PSP is bricked.
Please make sure that the unit is fully charged. I am charging my unit for 2 hours. Also, please try to turn it on while the power adapter is connected to the unit.
keeping Lithium ion batteries(found in ur psp) idle for such a long time without charging may discharge them compleatly and even if you try to charge them they will not function. this seems to be a problem with your battries not ur PSP. try to get it replaced from the dealer you bought the PSP from.
hope this solves your problem.. :D
the way 2 know if tis charging is wen u plug in ur charger 2 ur psp on da right a orange light should appear and stay ther eas long as its charging . wen it goes away it should be blank. if this doesnt happen on urs i dont know why. it should have come wiv a anual in ur psp box unless u have bought a used 1 from someone in dat case dey mite have not given 2 u for whatever reason. i hope dis helped=)
You don't have a problem; the seller is an idiot. Leave it plugged in for good measure, but your PSP is fine.
Many products ship with a completely discharged battery (many cellphones, for instance) and they must charge for a long time. PSPs don't; they ship with a partially charged battery.
