All cables connected correctly, but solution was much simpler - the device was not compatible with Windows 7 - switched to XP and was able to capture both video and audio without problem.All cables connected correctly, but solution was much simpler - the device was not compatible with Windows 7 - switched to XP and was able to capture both video and audio without problem.
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
I'm glad to provide the instructions to transfer video from VHS Tape to DVD. You may purchase a DVD Recorder and connect the VCR to its A/V input to record the videos directly to a DVD. There are VCR/DVD Combo Recorders available where you can dub from VHS to DVD without using another VCR.
Alternately, if you have an A/V interface in your Computer, you can connect a VCR to the Computer and capture videos using Windows Movie Maker or any other video capture software. Once you transfer the video to the computer, you can burn the videos to a DVD using the DVD burner in the Computer.
Thanks for understanding. Please let me know if you require further assistance or any clarifications.
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
you need to connect rca jacks or the mini jacks to the anolog side of your sound card and the 9 pin connector will use for video to capture aslo if your using windows movie maker you need to select the imput type and mpeg 2 or mpeg3.
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
I talked to someone who is a professional video editor, and he suggested the first thing to try was to change the USB port to which the DVD Maker was connected. This wasn't something which would ever have occurred to me, but hey presto it worked! Aparently USB ports are sufficiently delicate in terms of video transfer that they will work with normal devices, but some may not work well for video. I hope this helps someone else.
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
