Question about Lowrance Iway 500c GPS Receiver
We have a X23 Lowrance. It was working OK then it just went to flashing 0.5m with bits of blue colour over the screen. We have switched it off and then on again, but still flashing 0.5m. Can you help?
    Guru:
  • 597 Answers
First check and clean the transducer. Make sure it's level and clean of any dirt oil or fuel. You can do a hard or soft reset also but you'll lose all stored data and it will reset all of your settings. You can find out how to do a hard or soft reset on Lowrance hompage. www.lowrance.com I would get you the exact address but their web site is a little messed up this morning.
Posted on Jun 01, 2009
Have a Lowrance elite 4x chirp. What is the best screen color for bright sun
peoples eyes see colours differently my advice would be to go through the colour pallet & try each one till you find the colour that suits you will find a stand out colour for you.
Mar 08, 2017 | Lowrance Boating
Screen keeps flashing green-blue-red
The manual for the monitor can be found here (
Mitsubishi DiamondPoint V50LCD User Manual ) The specific Red Green Blue cycle isn't noted.
  1. I'd start with toggling on the on screen set-up display. if that comes up and is legible, then you know that the screen is working.
  2. What is your video set up to push to the V50? If it's not a supported resolution, the display may respond this way. try downgrading it something like VGA (640x480) and see if that works. (The max resolution shown in the manual is 1024 x 768, so don't go higher than that. It's also 24 bit color (8 bits each for R,G,B, so don't try to push 32 bit color to it)>
  3. Set the output to your primary monitor to 1024 x 768, thousands of colors. Make sure the monitor sees it OK. Now you know the first monitor and cable are OK. Now switch the cable to the V50 monitor. Do you get a signal now? Then the display works. Try putting your primary display on the second cable. Does it pick up anything now? No. Maybe a bad cable.
  4. You can try swapping the cable going to the V50 to go from your primary monitor output port on the computer to your primary monitor. if the primary monitor works OK, then the cable is good.
  5. Depending on the computer system you're on, make sure that you at least have a generic monitor driver installed for the V50 output. Ideally, get the driver for the monitor You can get the driver here (
Mitsubishi Monitor drivers ) amongst other places.
Nov 11, 2015 | Mitsubishi 15" Diamondpoint V50lcd-Bk Lcd...
Hi FixYa A query about my Viewsonic VA1932WMA screen. The screen works ok when the computer is on. However when I switch the computer off the screen starts displaying different colours - blue, red,...
If you have an older graphics card the signal will still be searching for a monitor. Contact Viewsonic and they will get you a non DDC adapter.
service.us@
viewsonic.com
or
T: (800) 688-6688
Good luck
Joe
Feb 20, 2011 | ViewSonic VA1932WMA Monitor
My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Apr 01, 2010 | Samsung LA40M81/BDX 40 in. LCD TV
When my iWAY 500c gets warm the touch screen will
I HAD THE SAME PROBLEM AFTER I DOWNLOADED THE LATEST UPDATE. I RELOADED IT AND NOW IT SEEMS TO WORK OK. GO TO THE LOWRANCE WEB SITE AND THEN TO DOWNLOADS. LOOK FOR THE UPDATE FOR YOUR GPS AND FOLLOW THE INSTRUCTIONS.
GOODLUCK
Jan 27, 2010 | Lowrance Iway 500c GPS Receiver
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Lowrance 3300c still playing up
John, my 330c was doing the same thing until I found a short in a totally separate system. It was a speaker for the stereo. As soon as I fixed it, the flashing problem went away.
Jan 08, 2009 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance 500c touchscreen
My iway 500c kinda had the same problem. At first while driving, the screen would go from 3d to always north to always up and be switching screens 3 to 4 times a second. It would finally go back to normal. After about a month of this the touch screen would work intermittently. It finally quit working completely on a trip to Texas. When I got home I called Lowrance and the said they would replace it for $350. I already spent over $600 for it. I took the thing apart and found the grounding screw to the touch screen was really loose. I tightened it and now its working again for now. I am not happy with Lowrance support.
Clane
Sep 05, 2007 | Lowrance Iway 500c GPS Receiver
Lowrance Iway 500c GPS Receiver Logo
746 people viewed this question
Top Lowrance GPS Experts
buzz flewhart
buzz flewhart
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
