Question about HP Office Equipment & Supplies
Have setup hp laserjet M1319 MFP series trying to fax but it does not seem to be sending it keeps redailing, phone line is in and i set it up by means of the cd that came with it
  • Anonymous Mar 18, 2014
    My Hp laserjet 100 color mfp m175a keep on displaying cool down mode. how do i remove this setting?
    Problem Solver:
  • 6 Answers
I have a different HP MFP, but had a similar problem. HP helpdesk wasn't able to help (had me update the bios, restart, etc.). I stumbled upon a similar problem on FixYa and found out that some of the MFP's aren't compatible with an office on a multi-line telephone system (something to do with analog).
I contacted my telephone service provider (which happened to be cable) and they made some changes to that line while I was on the phone with them. Worked perfectly ever since. I hope this helps you. Good luck!
Posted on Jun 25, 2008
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
I have trying to configurate the fax on an hp mfp 5025 and dont know the password for the service menu
You do not need to get into the service mode to program the fax on this unit. Fax settings are done from the control panel. Administration>Initial setup>fax setup.
Follow the send and receive menus to set what you need to.
Feb 19, 2011 | HP LaserJet M5035 MFP Printer
I can send a fax, but can not retrieve. Line continues to ring,
Press the START button while it is ringing. Scroll through the menus and set your machine to AUTO RECEIVE.
Jan 26, 2010 | HP Office Equipment & Supplies
We have a HP colour laser jet CM2320nf MFP and when we try and send a fax it comes up with error report Comm Error 345. Please explain
Check phone line. use a normal phone and plug into the same phone wall socket that the MFP is using, do we have a dial tone? Do we have a noisy line, any buzz or crackel will cause issues
If there is no dial tone ring line supplier, If it is noisy line do the same
Also check phone line is plug into "line" socket in the back of machine not "ext'
Also check no prefix is required to dial out, unit needs its own phone line..
Also try using resolution of fax as standard not fine, this requires less info to go threw the line
In Australia we have a thing called folds (fax online diag service), basicly it is a fax number you ring and the phone company who own the line send back a report, most times the issue is noisy line or no line available
hope this helps
Nov 27, 2009 | HP Laserjet CM2320nf All-In-One Color...
Have an HP Laserjet M1319 Fax Machine. Fax line appears to be working but I can't send or receive faxes. It shows"receive" when they come in, but won't print them up.
Sometimes these machines will give you automatic messege "Recieve."
If this is only plugged in the fax machine, can you hear the machine dialing or hear the machine recieving a dial tone?.
Some machines have the audio sound turned off, so it is quiet when the machine is doing fax transmissions to limit the noise.
If you can turn it on you can make this eaisier to resolve. If it is on then you can make this more simplier.
Make sure the settings are set right, Junk mail turned off, set up the fax answer mode to print, and not store, check to see if the auto confirmation can be turned on. When this mode is turned on for this process at least you can get a print out on the fax copy, some will give an error messege.
If you can put an analog phone into the fax line, use another phone to call that number and see if it rings. This will ensure the phone line is working well.
If this line has a phone line converter, digital to analong, this may cause some of the issues. More and more people are trying to use the internet as their phone line as a fax.
I would like to know if any of this resolved the problem. There are more questions I have to this type of problem.
Good luck.
Oct 16, 2009 | HP Office Equipment & Supplies
Modem fail errors between hp 4345 and savin mfp device
On fax settings set ECM to ON, JBIG to OFF, MAX BAUD RATE to 14.4, V34 to OFF then upgrade to latest firmware and make sure phone line is a 2-line phone line (look plug end of line and there should only be 2 metal strips on connector)
Mar 26, 2009 | HP LaserJet 4345mfp Printer
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
Hp laserjet m1319 mfp series
Are you using the software that shipped with the machine? I use the" HP Scan To" program which allows me to scan it to a slew of file types.
The only downer: I can't put the software on more than 1 computer. Apparently, it recognizes that the printer is hooked up to another machine and won't let me install any drivers on other computers (except the print driver).
Sep 25, 2008 | HP Laserjet M1319F Laser Multifunction...
90 people viewed this question
Ben Johnson
